Peugeot 307 Malfunction
08.05.2020 17:25 # 1
Naclore
Hello friends, I just became a new member of the forum.
My problem is that in my car recently I got the Antipollution Fault and Automatic Gear Fault error. Transmission valves will change, he said it will be 340TL.
I saw it at peugeotmarket.com, there is 120TL, but he says there is not the same thing. div>
I'm going to ask a few more things & nbsp;
1) I have a problem with the temperature in the car. coming up. When I came home today, I closed the car, I was looking at the document, suddenly steam started to come out of the engine, I opened the hood, the engine had boiled water, but the fan was not working. >
2) When I got the car, the driver's armrest was up and the screw of the armrest of the rear seat was removed. Can I do this myself or does it have to go to the upholsterer?
08.05.2020 17:25 # 2
EnSoNiQ
hocam electro valves you can buy the solenoid valve you call from peugeotmarket. Now it would be wrong to say anything from here.
08.05.2020 17:25 # 3
Naclore
Well I will take into account what you say, I hope there is nothing serious in the gearbox, or the engine has already taken off the car the next day, the timing broke off a little bit of a headache.
08.05.2020 17:25 # 4
SserkanT
I said, let's continue from here so that the issue is not polluted. As of this morning, automatic gear I have joined the caravan of fault warning areas "Shocked" & nbsp; about 1000 km ago, I changed gearbox oil in a special service of a different company, now I understand that I made a mistake. For the selonid + oil change, it does not matter in Istanbul, Europe. & nbsp;
08.05.2020 17:25 # 5
fexzi
Replace gearbox oil
Replace solenoid valves
Have the operator control the thermostat activated.
If the
fan does not turn on, check that the fan coil is not receiving current.
similar topics are available in the forum Let's investigate a bit :)
08.05.2020 17:25 # 6
SserkanT
[QUOTE = fexzi] Replace the gearbox oil
replace solenoid valves
have the customer activated the thermostat.
If the
fan does not turn on, the propeller coil is not receiving current.
Let's look at similar issues available in the forum :)
[/ QUOTE] Thanks for your
relevance and suggestions will definitely work for me. I had asked for help in a honest place with the job I could do in Istanbul.
08.05.2020 17:25 # 7
fexzi
[QUOTE = SserkanT] [QUOTE = fexzi] Replace the gearbox oil
If the
activates the thermostat, check the propeller coil. / div>
similar topics are available in the forum, let's investigate a little bit :) I had asked for help in a honest place in the business that I can get them done in Istanbul. / div>
