peugeot 307 lpg problem
08.05.2020 15:08 # 1
arslanbey01
friends peugeot 307 1.6 comfort 2006 new case I got lpg on the vehicle atiker brand in general I heard that peugeot and especially 307s have problems in lpg. After wandering with LPG for 2 days, the engine warning light came on and an article appeared as an antipolition. I went to the private service outside, and they looked at it, it is normal for peugeot people who said that the malfunction is related to the air flow. they turned off the fault light. I walked until the evening light did not come on again, but they said it is still normal. So is there a way to prevent this? It is normal for the peugeot 307s with LPG to do so, or what should I do to get rid of this, some say replace the spark plugs. I am waiting for your opinions, if you answer, I would be glad if you answer thanks: =)
08.05.2020 15:08 # 2
trtolgi
my slumber had the same problem in my hand.the burning of the light gives a warning if I don't get it from lpg den.be every time I bought it.I did a ke.
08.05.2020 15:08 # 3
sercinho
man, it may burn but I recommend you read the articles written by our brother cecoli about this issue.
08.05.2020 15:08 # 4
Here, this anti-pollution fault indicates that the mixture lpg mixture is not correct. If it does not malfunction while at gas station, the reason is usually the LPG setting. It will not light if the correct setting can be made. Most of the masters say that it is normal for the lamp to turn on because they cannot catch the correct setting. because they do not want to deal with it. Let them come and tell me to my ear. There is no 307 wandering in the market without the failure light burning :)))))
If the fault is also on gas, it can be assumed that the oxygen sensor is faulty.
it can also be tried as soon as it does not hurt to change the spark plug ...
08.05.2020 15:08 # 5
sercinho
I have 14 days of lpg and there is no problem.
08.05.2020 15:08 # 6
[QUOTE = sercinho] mine is 14 days with lpg now there is no problem I agree with my brother cecoli [/ QUOTE]
I couldn't remember what brand was scarce ???
08.05.2020 15:08 # 7
tufan31
2002 xt. I have the old system lovato, thank goodness there is no problem. Like gasoline ...
08.05.2020 15:08 # 8
metin
I have been in custody for 5 months, I have done more than 5,000 km neither light, nor a problem.
08.05.2020 15:08 # 9
It was 1 month since I plugged in. It burned a second time. The man is connecting to the computer. copying gasoline settings and pasting it into lpg. He did so in the first, but he burned again for the second time. I couldn't go yet. I will have it checked. why is it burned? The man said that he had hit the crankshaft at first, but I fell over because I did not understand. what interests me was that it was extinguished. I came and came. Let's see what happens this time?
08.05.2020 15:08 # 10
volkan_uysal
It is not worth the evil eye. I have been using for 6 months, I have done 14000 km Sırıtma
