PEUGEOT 307 knock sensor
08.05.2020 19:10 # 1
E.B
Good evening, my friends had a catalytic converter malfunction while I was on the road about 2 months ago.
I did not use it for about a month, when I got on the car, I started the computer which had antipolution fault and gave the attached error codes
what is this knock sensor friends?
I deleted the error codes. It was 1 week. What light did the engine do?
By the way, I do not understand the reason why the photo is constantly reversing.
the http://www.fotokritik.com/3224742/fotokritik-fotograf EB 2015-03-21 12:04:33
08.05.2020 19:10 # 2
E.B
date ...
08.05.2020 19:10 # 3
E.B
For example, when I climb on something I want to add, I would accelerate slowly from 3 to 4. When I reach 2000 cycles, I don't know if the car would be connected for 1 second or half a second after gas cut.
08.05.2020 19:10 # 4
vpro
There are bishops on this subject, hodja
the http://forum.peugeotturkey.com/forum_posts.asp?tıd=36183&title=sente-ayari-ve-vuruntu-sensor
08.05.2020 19:10 # 5
E.B
Thank you, I have read this topic. Do you think it is from the sente setting?
Now I came from the master, we connected the computer, it did not show any problem with the PC, he did not write anything about the knock
08.05.2020 19:10 # 6
E.B
friends, can you comment on this?
the car does not stall when it comes to 2000 revolutions in 4 and 5 gears on the straight road, but when the mountain comes out, 4th and 5th There is a misfire of 0.5sec at 2000 revs after the gears, then start eating gas again
08.05.2020 19:10 # 7
E.B
date.
