Peugeot 307 - How to Remove the Shift Knob?
08.05.2020 14:52 # 1
Bahadir
Friends. I Bought Myself A New Gear Shift Knob. But I couldn't disassemble my Original Gear Knob. About This Topic Someone Illustrated etc. I would be glad if it helps me. Thanks in advance. Bahadir 2010-08-13 15:37:04
08.05.2020 14:52 # 2
Bahadir
Friends Won't Take Off That Shift Knob?
08.05.2020 14:52 # 3
xMEGANx
08.05.2020 14:52 # 4
xMEGANx
I hope this photo has been descriptive enough;)
08.05.2020 14:52 # 5
Bahadir
Man, good bye, twist it, twist it, nothing happens. It just spins in the case under it.
08.05.2020 14:52 # 6
xMEGANx
Peel the bellows upwards, the old gear knob is fixed with a clip-like piece, if you remove that clip or that spring, the knob will come out.
08.05.2020 14:52 # 7
GokhaN
Rotate it 90 degrees, you will probably break the plastic underneath but it will come out like that
08.05.2020 14:52 # 8
master
cut the clip under the bellow with its echo,
Turn the knob a quarter turn clockwise,
put your leg on the passenger's side and ...
I cut it because it's been too long recently.
master 2010-08-15 04:38:32
08.05.2020 14:52 # 9
Bahadir
I will try it Thank you very much for your attention.
08.05.2020 14:52 # 10
alpbeyazi
you break the deal ..
08.05.2020 14:52 # 11
kabusizmit
My friend changed it too. When it pulls towards itself, it knocks out strongly. There is something white silicone ghib that makes it short for a short time. It is nice. Tuning ciler is not a problem.
08.05.2020 14:52 # 12
gozem
With the information I got from here, I renewed my gear knob today.
If there are still those who couldn't, I took pictures within them. Ancan xMEGANx did not come out of the shaft as in the picture put by a friend.
If you are interested, I will send the pictures.
08.05.2020 14:52 # 13
alpice
I would appreciate it if you can tell me how to disassemble the Gear Knob. I have to change it too
08.05.2020 14:52 # 14
[QUOTE = alpice] I would be very happy if you could tell me how to disassemble the Gear Knob. I need to change it too [/ QUOTE]
It does not matter whether you shift the knob of the gear around 90 degrees to the rear seat. Then no matter what God gave up. Let me sweat from the head and don't hit your head when it comes out, don't let the knob come out and come to your face.
08.05.2020 14:52 # 15
Ozgur
just as the cookie explains. Flip it 90 degrees is really difficult to hang. But watch out.
08.05.2020 14:52 # 16
metin
I have an automatic gear, too long is it possible to shorten it?
I said let me ask when the ready topic is opened and the masters are here.
08.05.2020 14:52 # 17
martial307
What if I don't have all the gear instead of the gear shift knob?
08.05.2020 14:52 # 18
[QUOTE = martial307] or brother, instead of the gear knob, I don't have all the gear, can you teach me how to take it off and put it on [/ QUOTE]
It does not come. Strongly noble. It makes me sweat a lot but finally comes out. Be careful not to face your face when you suddenly come out.
08.05.2020 14:52 # 19
Ozgur
RIGHT LEFT MAKES IT REMOVE. Beware that it gets a little hard.
I EXITED 1 MONTH BEFORE.
08.05.2020 14:52 # 20
okan4037
What if we changed the gear knob, it was old, I bought a new one, but then I realized that it turns when the gear knob turns? the other constant was how we can stop it from playing
