Peugeot 307 Horn Oxidation Removal.
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 14:07 # 1
hasimayaz
First, we removed the Ignition key. We remove the battery terminals.
By pushing the airbag lock forward with an appropriate sized flat screwdriver, we ensure that the airbag comes out. At this point, we have to be very careful, we will need some strength from the outside, we have to support the release of airbag with your other hand. Lock springs must not be damaged. We must adjust our strength well, neither too much nor too little.
The red arrow shows the spring pushed by the screwdriver, the blue arrow locks holding the airbag, the Blue arrow shows the horn chassis.
We carefully remove the chassis socket.
Let's clean the chassis connection and the contact points of the horn with fine nail file or 0 number sandpaper.
Let's stretch the chassis socket a little and grease it with contact grease. Contact Cleaner can help us with the spray.
08.05.2020 14:07 # 2
BurcUMUL
this is a general peugeot problem. I had the same problem with my horn. But thanks to my master, he did it, but I don't know how. Maybe as you say ...
08.05.2020 14:07 # 3
Celalettin
Congratulations Haşim usta. You have transferred the process very well. It is very nice that you support the process with photos.
08.05.2020 14:07 # 4
entel
One of the works of Haşim Usta that will pass to the literature again ..
I am a health master at your labor :)
08.05.2020 14:07 # 5
pug307_26
I have this problem, it was working according to the head. Thank you very much.
08.05.2020 14:07 # 6
g-demir
your health care master, you have enlightened
08.05.2020 14:07 # 7
Carmania
As always, you congratulate Haşim Usta, number 10 again. Alkış
08.05.2020 14:07 # 8
m1976k
oh gidi ah last week i had my master pulled the air burner plug we had to put the api to the top one, the oxide cleaning of the horn cost 40 tl would be nice if the subject was opened beforehand but still your hands to your health ..
08.05.2020 14:07 # 9
[QUOTE = m1976k] ah gidi ah last week I had my master pulled the air burner plug we had to put the api to the top, the oxide cleaning of the horn costed 40 TL, it would be nice if the subject was turned on beforehand, but it is still good for your hands .. [/ QUOTE]
Subject 1 year Embarrassed
08.05.2020 14:07 # 10
syz33
Yes, one of the classic peugeot problems was in my vehicle, there were similar problems, but it repeats over time.
08.05.2020 14:07 # 11
feline
awesome sharing congratulations
08.05.2020 14:07 # 12
Wlkn
Master, if we contact you (: there is a 307 kisses on their hands
