peugeot 307 help
08.05.2020 18:21 # 1
E.B
Friends, good morning, I hope you can write on the wire.
10 days ago, there was a sound coming from the cups. I was getting another strange sound with him. Anyway, we showed the master, the room was in control, the engine was going to be gone. And we changed the cups, there is Allah, when the engine was opened, I was there, what a mess, something was clean, a single cup was bad, whatever it was, and I took the car, I paid 1500 TL money, it was made in full maintenance, the water pump was changed, I took the car and tested it. When I pressed the clutch, the sound of the night is cut off, the master said, "I said," Use a few guns in the clutch ball. " what do you do
There is one more thing, I am sure that when the ball is cold, when I first start it, it enters the gear when it starts, but it does not have a problem, believe it, it goes on slowly, it goes smoothly, but I do not have a problem. to come out
And it was as if the car had been attacked in the past. Now it seems as if something tutuu pushed the compression values increase after the master segment, but there is no room. Let me sit a little bit, but what would a non-urgent transmission sit?
08.05.2020 18:21 # 2
sosyete_60
brother, first of all, calm down, do not despair, what you said is in me, I made the gearbox, I have changed the whole ball set, the pressure, the ball of printing, but there is still a thin voice
08.05.2020 18:21 # 3
slhyldz
[QUOTE = EB] Friends, good morning, I hope you can write on the wire.
And it was as if the car had been attacked in the past. Now it seems as if something tutuu pushed the compression values increase after the master segment, but there is no room. Let me sit a little bit, but what would a non-urgent transmission sit? [/ QUOTE]
Hi;
I had a 1993 model seat ibizam. The situation you described was in me. They called me a ball. We gave it to the gearbox in Kartal industrial site. The result is frustration. Your transmission was lean and the inside was black. I bought a gearbox, got rid of it. I think the owner before me hit the gearbox from the bottom and used it in such a way that the oil was drained. There was a scar on the crankcase cover and the plug was attached with silicone. But it is interesting that this sound came out after the construction of the engine. It is useful to show it to a different master.
08.05.2020 18:21 # 4
scorpion_enis
It is unlikely that there will be any sound from the gearbox after the engine is built, perhaps you did not hear the sound of the engine, the sound of the gearbox. The sound comes from the balls. In a very quiet environment, the sound decreases when you normally press the drain, this is normal to a certain extent, but if it is too much to be heard during the day, it is most likely from the balls. It is not a very expensive process if it only comes from balls. God bless you.
