Peugeot 307 hdi premium air conditioner problem
08.05.2020 17:33 # 1
poyrazkuzey
Hello guys
I started using the air conditioner since the heat started suppressing, but for a few days it was blowing hot, I immediately took it to the master because there is a digital air conditioner, the master said that the engine that distinguishes the hot cold was faulty, it did not do it because there were no parts Unfortunately, does anyone know about the price or have anyone experienced this problem before?
08.05.2020 17:33 # 2
mehmet_2
I also have the same problem, but it may not be from the engine. The plastic router inside the box may also break. If the master checked or shook right away, it may be stuck, it may be from the gear that the engine is turning.
08.05.2020 17:33 # 3
poyrazkuzey
How did you find a solution? Did you fix the problem?
the master looked and said that he was from the engine.
where can I get a suitable price?
the air has changed to the air, but it does not change the hot cold air, the air conditioner
08.05.2020 17:33 # 4
pt206
I was blowing hot too.I pressed the air conditioner gas now, I got it, maşallah, it doesn't stop when it cools down Smile
08.05.2020 17:33 # 5
polater
Although the plastic router inside the box is very likely to be broken, it may be finished in gas. However, it happened to me, even though I set both sides of the double-sided air conditioner to the cold, the right side was blowing hot, the plastic part changed from the system, the problem was solved, and then both started to blow hot, I filled the gas, the problem was solved.
08.05.2020 17:33 # 6
SDYMZ
the gas is missing if it comes out of the right ventilated and a little cold from the left, so it does
08.05.2020 17:33 # 7
ismailkaya
http://www.youtube.com/watch?v=S8s7DrcegDQ let's see how air conditioning in one place
