Peugeot 307 Excessive Sound Problem
08.05.2020 21:08 # 1
Begruzi
Hello friends,
I need the opinion of experienced 307 owners. My goal is not to deal with extra insulation, but the vehicle gets an incredible engine sound inside. Although my car is gasoline, it is very uncomfortable for such high engine noise to come in.
Now, my question is, if the car was made in 2004, all of the seals were worn, the worn-out pinch, and the hood seals from scratch would this high engine and rpm sound coming into the vehicle be cut off or at least to some extent?
If it does not work, I would like to ask if there are other solutions. I don't want to make an extra charge for this problem.
the Begruz 2019-01-29 20:49:54
08.05.2020 21:08 # 2
talip206
Is your vehicle automatic?
08.05.2020 21:08 # 3
ismailkaya
it's time to change engine oil
08.05.2020 21:08 # 4
Begruzi
auto auto yes, engine oil has changed more recently, I bought the car as a second hand, I put it in full maintenance recently, it can not be related to engine oil. paykas to the Begruz 2019-01-31 01:07:25
08.05.2020 21:08 # 5
talip206
[QUOTE = Begruzi] vehicle auto yes, engine oil has just changed, I bought the vehicle as a second hand, I put it in full maintenance a short time ago, it has nothing to do with engine oil. [/ QUOTE]
Unfortunately, the automatic vehicle screams a little. It is one of the things that people who have not used automatic gears are most concerned.
But the noise I'm saying is what's on the move. It runs silently while idling. If there is noise in idling, it is necessary to check the air filter and its extensions. It may not be fully seated after maintenance.
Apart from that, I don't think there will be anything to be solved with much insulation. But if there is no insulation material in the hood, it can be taken and installed.
talip206 2019-01-29 21:18:15
08.05.2020 21:08 # 6
Begruzi
There is no sound at idle, the car's engine sound almost does not bother, it does not bother inside, it just takes a lot of noise at the points where the speed rises in low gears, every vehicle gets at this point, but I realize that this is a little more disturbing than other vehicles, let's take the insulation material in the hood and let's try it.
08.05.2020 21:08 # 7
Cemm
[QUOTE = Begruzi] vehicle auto yes, engine oil has changed recently, I bought the vehicle as a second hand, I put it in full maintenance a short time ago, it has nothing to do with engine oil. paykasa [/ QUOTE]
Brother, because the vehicle has 4 gears, you will hear all kinds of engine rpm, idle operation, it is necessary to look at the noisy manifold outlet.
Jammu 2019-02-05 11:40:48
08.05.2020 21:08 # 8
Kuzey58
[QUOTE = Begruzi] Hello friends,
In my car, the automatic 2003 model has the same sound problem. I aim to solve the sound problem with the insulation material. The sound comes from the front console. Now my materials are on cargo. After applying the materials, I can share the result with you. Smile
08.05.2020 21:08 # 9
Proctives
[QUOTE = North58] [QUOTE = Begruzi] Hello friends,
If you bought the materials, which material did you share? If you have applied it, I am very curious about the result. Thank you from now. :)
08.05.2020 21:08 # 10
prens3574
I have the same vehicle in my car while it is making a lot of noise, dabluvbazlar sound comes from some broken places.
08.05.2020 21:08 # 11
maximusti
Could the manifold leak?
