Peugeot 307 Does Not Take Gas For 1-2 Seconds, Then Suddenly |
| 08.05.2020 15:58 | # 1 |
This situation is rare, but it happens from time to time. Especially |
| 08.05.2020 15:58 | # 2 |
Welcome, Mrs. Zeynep, First of all, I would like you to introduce yourself according to the information I have given below. In this way, we will have a chance to get to know you and your vehicle better. 1.- Your name and surname: 2.- Your age: 3.- Your vehicle (Brand, model): 4.- Your hobbies: 5.- Your profession: 6.- Where did you hear the site: 7.- Your Blood Group: 8.- Your horoscope: 9.- The team you support: 10.- Which county or province are you in: 11.- Your MSN address: |
| 08.05.2020 15:58 | # 3 |
If we come to your problem. Does this problem when the vehicle is going on gasoline, have you ever tried this? |
| 08.05.2020 15:58 | # 4 |
I think it is normal that mine is in diesel, when it is loaded suddenly, there is a jump and then megan in megan. I think it may be related to the electron gas system.
| 08.05.2020 15:58 | # 5 |
I found the site while browsing the internet. I live in Istanbul, I am from Galatasaray. My vehicle is 2005 model XR.
| 08.05.2020 15:58 | # 6 |
Welcome to us Zeynep Hanım, I would like you to introduce yourself according to the information I have given below, first of all. In this way, we will have a chance to get to know you and your vehicle better. |
| 08.05.2020 15:58 | # 7 |
automatic gear I think your vehicle may have a problem in the transmission
| 08.05.2020 15:58 | # 8 |
Mrs. Zeynep, This problem has nothing to do with neither gasoline nor LPG. I have the same problem with gearbox. I have visited about 10 masters. 1 authorized 2 special services. The complete revision of the guaranteed gearbox is the first I mentioned. 900-1000 second, I said 2000-2500 TL. In my personal opinion, when the complete revision gives another malfunction after two days, the gearbox will be overhauled, and you will be bored with the second one. Once done, 100 thousand km will not hurt your head. Of course, the opinions of experienced friends are more important. |
| 08.05.2020 15:58 | # 9 |
The same problem happens in my vehicle LPG, not in gas. I think it's about LPG. If it does the same problem when taking off in the manual part of the tiptronic, it is called LPG.
| 08.05.2020 15:58 | # 10 |
[QUOTE = exssen] The same problem is on my vehicle LPG, not on gasoline. I think it's about LPG. If it does the same problem when taking off in the manual part of the tiptronic, it is called LPG. [/ QUOTE] I also suspected lpg first, because this happened after I installed lpg. but the problem happened after switching to gasoline, even after removing the lpg temporarily.
| 08.05.2020 15:58 | # 11 |
I have the same problem in me, but it was after lgp in my mind, but I think it is a problem with the transmission, but it was not the kind that would create a problem. I'm not even going to change the oil |
| 08.05.2020 15:58 | # 12 |
mon |
how many kilometers it has been to replace the spark plugs.
| 08.05.2020 15:58 | # 13 |
[QUOTE = mon] how many km has been replaced with spark plugs. [/ QUOTE] It has been 2-3,000 kms since I renewed my spark plugs.
| 08.05.2020 15:58 | # 14 |
tazmaniac |
By the way, you have mentioned that you have removed the LPG. It seems that it has been dealt with. The gearbox is automatic or automatic.
| 08.05.2020 15:58 | # 15 |
If it seems to me, it looks like your luck, but I would recommend it to the master who makes it the most comfortable heat.
| 08.05.2020 15:58 | # 16 |
[QUOTE = tazmaniac] You have mentioned that you have removed the LPG in between. [/ QUOTE] only the connection on the engine was removed. I mean, not much effort. vehicle automatic transmission.
| 08.05.2020 15:58 | # 17 |
I say distress gearbox does not provide lpg to these vehicles
| 08.05.2020 15:58 | # 18 |
[QUOTE = ismail özdemir] I say distress gearbox does not benefit these vehicles lpg [/ QUOTE] How can lpg directly damage the transmission?
| 08.05.2020 15:58 | # 19 |
34sea45 |
I do not know the lpg section, but the late reaction to gas in automatic cars is something that is very frequent, so the civic focus cmax I was driving was like that
| 08.05.2020 15:58 | # 20 |
tazmaniac |
[QUOTE = 34sea45] I wouldn't know the lpg section, but the late reaction to gas in automatic cars was something that was very frequent, so it was the civic focus cmax I drove in [/ QUOTE] friends have already determined .. all of the auto cars that my friends have been driving were like that, so I wouldn't want to get the automatic gearboxes, but how do I say You can not judge the car as you want, since you can not adjust it from the clutch after starting with automatic gearshift fabricated gear ratios, either during start-up or intermediate accelerations. |
