Peugeot 307 Does not eat gas :( Please help (ÇÖ
08.05.2020 19:25 # 1
MagicTR
Hello, I have 2 problems in my vehicle, I am waiting for your solution suggestions. I'm nervous :(
1- There is a problem of not eating gas in the vehicle. LPG is not installed. When the vehicle is cold, it does not eat gas and vibrates excessively. When the temperature indicator is 90, flickering stops and normal gas is eaten. While pressing the gas, the speed increases, the speed increases, but the vehicle does not go.
2- When the temperature exceeds 90 and when I take my foot out of the gas, the warning of oil is flashing. The warning disappears when you press the gas again or when the temperature is 90 or below.
Thank you in advance for your interest. MagicTune is 2015-10-04 07:37:09
08.05.2020 19:25 # 2
MagicTR
// Current
08.05.2020 19:25 # 3
vehicle auto coach
08.05.2020 19:25 # 4
MagicTR
No teacher manual gear
08.05.2020 19:25 # 5
oguz41
Hello, because he mentioned about other issues mentioned, based on those ideas, the circuit clutch sign indicates that the pad is dead. He even writes that this is the explanation of the interruption of the tremor event. There are articles about whether the printing is finished or not.
2. Good forums I don't know your problem.
08.05.2020 19:25 # 6
MagicTR
Hello again,
The vehicle's problems have been solved. I wanted to write here and inform you. Maybe it will help other friends as well.
I replaced the Knock Sensor for Issue 1. I cleaned the intake manifold and throttle.
2. I solved the problem by replacing the oil pump and filter.
Good forums
