Peugeot 307 does not eat gas in 5th gear.
08.05.2020 18:20 # 1
mrkync
Friends I have the 2005 model peugeot 307 1.6 hdi. I have trouble accelerating my car for about 2 weeks. The vehicle accelerates until 4th gear, but when I step into 5th gear, the speed remains almost constant in 4th gear and does not eat gas. Sometimes it returns to its former state and takes over very quickly. When I had my car installed on my computer for some other reason, I saw that it gave the electrovan error, but they said it was not a problem, and I deleted the error and continued, can this be caused by the electrovan or is there any problem?
08.05.2020 18:20 # 2
hsnsnl
teacher, I open the turbo and I know the door is closed.
08.05.2020 18:20 # 3
mrkync
Teacher, I had him checked, but the masters said there is no problem. However, the vehicle occasionally returns to its original state. I do not understand this. During the past 3 days, the vehicle has continued its uneventful road and speed, but today it has not accelerated again. Moreover, it does not show any signs of error. A few masters said there was a problem with my clutch lining, but some masters say that even if it is a clutch lining, the error must continue. I could not decide whether to change the printing pad or not. They make changes to 600 TL, but I am afraid that the error will continue after they change. Have you ever had such a problem?
08.05.2020 18:20 # 4
mrkync
Guys, I noticed one more thing today. When I bring the cycle to 3500 when the vehicle is idle, it automatically pulls it back to 3000. No one is faced with this problem?
08.05.2020 18:20 # 5
ahmet_bjk
It does all the gears even if it has a lining.
If the vehicle drops from 3500 rpm to 3000 rpm, it does not exceed 3000 rpm, so 3 messages may be the situation mentioned by our friend hsnsnl above.
08.05.2020 18:20 # 6
mrkync
Friends, we found trouble, we changed, the problem is solved. If you encounter such a problem, the solution comes from the turbocharger of your turbo.
