Peugeot 307 Digital Air Conditioner Problem (With Video)
08.05.2020 18:42 # 1
E.B
Friends Good evening
As shown in the video, my digital air conditioner works sogutuo does not blow itself off after 10 seconds.
In my research, they said air conditioning resistance or something, but this problem?
https://www.youtube.com/watch?v=hw-xı9sgoba&feature=youtu.b to
08.05.2020 18:42 # 2
E.B
Does anyone have information ? do not leave your water friend at 40 degrees without air conditioning :)
08.05.2020 18:42 # 3
emrepunar
If you do research in the form that many things have been tried in the past, you will find detailed explanations.
08.05.2020 18:42 # 4
cyberturk
Hello my friend came to my head when I brought the clover leaves to the end of the digital air conditioner stopped blowing, then it was not working. but we found the problem just under the steering wheel, something like a cover war, take it out, you will see the radiator engine in the back. doing it because of that. When you bring that socket to level 4, you will see that it works a little bit.
08.05.2020 18:42 # 5
scorpion_enis
the same problem is with me, if the vehicle stopped without seeing the temperature, the air conditioning operation time is more. But as you said, you stop blowing off, you turn it off after a certain time, it works again, but this time it stops blowing faster. If you have a problem, definitely the problem is in air conditioning resistances. Something around 150 TL. The problem is solved when he changes it.
08.05.2020 18:42 # 6
fexzi
There is a service price of 160 TL in the form of air conditioning resistor in the form of the moon. The problem goes away. I tried the same problem. I tried to change the components but I did not eat it.
