Peugeot 307 diesel drain
21.07.2021 13:46 # 1
Hoholiss53
Selamun aleykum friends
For God's sake, someone help me. I'm about to go crazy
My Peugeot 307 1.4 hdi xr has a fuel leakage problem.
There is an explosion in 4 steel pipes coming to the injectors. It did not change with the originals
We did not get out. Yesterday, while going up the ramp in 3rd gear on the way to the village
I pushed the car a little bit, and the smell of diesel came to the mountain again. I don't think it has anything to do with pipes. Because it changed 5 times. I finally got it welded. Is this a problem related to pressure, please help, give some advice
21.07.2021 14:09 # 2
omerb
Hello. There may be a problem with the high pressure control valve. The high-pressure pump pumps the fuel at high pressure, a small amount of it is injected by the injectors, and the rest is passed through this valve, circulating it continuously at low pressure. If this valve is defective, it may not be able to return and burst its hoses. Also, don't you get error codes etc related to high pressure?
21.07.2021 14:13 # 3
Hoholiss53
The car does not show any fault codes on the screen, bro.
21.07.2021 14:41 # 4
omerb
Now, if I say that the return hoses are clogged, it is very unlikely that all 4 of them will be clogged. Sounds like there is a problem with the return system. It could be a pressure regulating valve. There are videos about the operation of this system. If you want to watch them, you can have an idea.
I think this system is called common rail. If you search you will find videos.
Don't bore it.
21.07.2021 17:57 # 5
Hoholiss53
Bro I removed the upper air filter box
The rightmost diesel leaks from the pipe next to the filter where it enters the injector.
21.07.2021 18:04 # 6
omerb
Is it leaking through the pipe? Or did the pipe burst again?
21.07.2021 18:06 # 7
Hoholiss53
It leaks from the port where it enters the injector in a pressurized way.
21.07.2021 18:14 # 8
omerb
Could it be that a tooth has been skipped or stripped? The hose did not burst.
24.07.2021 21:41 # 9
Hoholiss53
bro i think i found the problem
Injector ramp to which the records are attached or
The injector stump is not stable, I can move it with my hand.
I've investigated and there's cracking in the record connection places due to vibration
I think it's happening. Intake monifold will be disassembled and examined in detail
24.07.2021 22:38 # 10
omerb
Well. I hope it will be solved without too much cost.
