Peugeot 307 cruise control assistance
08.05.2020 16:50 # 1
muratoner
& Nbsp; Hello friends my 1.6hdi premium 110 hp & nbsp; & nbsp; The brain of my vehicle is written on bocsh 16+ c34.
08.05.2020 16:50 # 2
You should check the brake mat before installing. Brake cable, how many cables and how many?
08.05.2020 16:50 # 3
muratoner
& Nbsp; My brother Koliva looked at the brake sender. There are 4 cables connected, even my vehicle is full, but there is no speed stabilizer. I will do the assembly myself, but I would be glad if you help to activate.
08.05.2020 16:50 # 4
[QUOTE = Muraton] The & nbsp; My brother Koliva looked at the brake sensor. There are 4 cables connected, even my vehicle is full, but there is no speed stabilizer. When you look at the steering wheel from below, you will see two allen screws. The bottom of the socket will open them. Then you will see the location of the cruise control under the signal lever. It was originally covered with another plastic. You can easily remove that piece and attach the cruise control arm. In the plastic cover you have removed, the speed stabilizer has not been cut. You will open your home with a falcate or knife. Then you will put the plastic cover back on. Apart from that, everything will be done with PP2000. In that part, you will probably make a friend you mentioned. Are you sure he has PP2000?
08.05.2020 16:50 # 5
Alicilik
Connection with PP2000 is a must to activate. Aykut (koliva) will help the rest if you have it.
08.05.2020 16:50 # 6
muratoner
My friend does not use pp2000. A different program that he uses does not know which vehicle brand you choose from all the vehicles. His room doesn't know anything like that.
08.05.2020 16:50 # 7
muratoner
By the way, whatever happened, I shot the PP2000 program from the net.
08.05.2020 16:50 # 8
[QUOTE = muratoner] In the meantime, what happened die I pulled the net of the pp2000 program. [/ QUOTE]
Yes, without PP2000. Other devices only work to read error codes and do minor things. With PP2000, you can do anything except throwing software related to your vehicle (if you are an authorized service, you can do it too).
Also, since it can be downloaded from the net, why do they ask for this much money? "T
08.05.2020 16:50 # 9
istanbullu_3886
Only the pp2000 program is not enough, you need to use the obd cable and the device that will connect with the arc.
08.05.2020 16:50 # 10
muratoner
& nbsp; Koliva brother pp2000 I downloaded last night with a total size of 3.5 gb. If I open it with pp2000, what commands should I follow? Can you help me with pictures. Even vista is not installed xp is installed in the program & nbsp; opening pejo ampema comes.
08.05.2020 16:50 # 11
muratoner
If the obd cable fits the cable that your friend is using, we will connect with it and let's see.
08.05.2020 16:50 # 12
[QUOTE = muratoner] & nbsp; Koliva brother pp2000 I downloaded last night with a total size of 3.5 gb. If I open it with pp2000, which commands should I follow? Can you help me with a picture? Even vista is not installed xp is installed in the program & nbsp; opening pejo ampema comes. [/ QUOTE]
I guess I couldn't explain it in my above message. Do you have this device?
Reviews
08.05.2020 16:50 # 13
muratoner
friend has a device like this but no such amplem over :(
08.05.2020 16:50 # 14
[QUOTE = muratoner] friend has a device like this, but there is no such ample on it: ([/ QUOTE]
In any case, the point you are going to freeze around is PP2000 "LOL"
If you don't have a friend, you will either go to a service or get yourself a PP2000 "
08.05.2020 16:50 # 15
muratoner
& Nbsp; You're right, koliva brother, I bought the device today, assembled it myself, went to a friend, we connected it to the device, but this device does not open any menu related to cc. I talked with a citroen service from Kayseri, we have a program called lexia. If I will not travel 150 km in vain.?
08.05.2020 16:50 # 16
[QUOTE = Muraton] The & nbsp; You're right, koliva brother, I bought the device today, assembled it myself, went to a friend, we connected it to the device, but this device does not open any menu related to cc. I talked with a citroen service from Kayseri, we have a program called lexia. If you will not travel for 150 km in vain. ?Uthentic/QUOTE]
I think the device you use is not PP2000. PP2000 is not external, it is certain, so don't insist on it "Smile"
Lexia is a software for citroen vehicles. In other words, the device used by Lexia and the device we use are the same and the device in the picture above. I think the service with Lexia probably has software for PP2000. If they can, they can. I do not know if 150 kilometers will change or not because I do not know the skill-deficiencies of the masters "LOL"
08.05.2020 16:50 # 17
muratoner
& Nbsp; & nbsp; Let's say good luck. But if there is a place that you know I will go to Ankara on the 22nd of this month, I would be glad if you say it. Thank you very much.
08.05.2020 16:50 # 18
[QUOTE = is Muraton] & nbsp; & nbsp; I Hayýrlýsý diyelim. Napali get a place but if you know that in the 22 months I go ankaraya thank AQ If you enjoyed olurum.çok. [/ QUOTE]
I veremeyeceg information from yasamadigi in Turkey. I guess Ankara friends will help.
08.05.2020 16:50 # 19
muratoner
Ankara friends help please !!!!!
08.05.2020 16:50 # 20
muratoner
& Nbsp; & nbsp; Yes, friends, I finally got a cruize control. It didn't take 5 minutes. & Nbsp; :))) & Nbsp; I hope it happens in those who do not. But let me tell you something super. I recommend it to anyone.
Page : / 4
