peugeot 307 control problem
08.05.2020 18:13 # 1
zorvolkan
Friends 2005 model & nbsp; Peugeot 307 we have a car. The remote control did not lock out suddenly at night. Can there be a high cost and how can I solve it? (Car central lock is working from inside)
I am waiting for your help
08.05.2020 18:13 # 2
What can be the problem if the battery is not exhausted. There is no need to register keys again because the vehicle will not start if the immobilizer is distressed. Even if the battery is not exhausted, it does not make sense. Maybe it's not carving instead of battery, but you don't realize it's over.
08.05.2020 18:13 # 3
zorvolkan
[QUOTE = dogancanguden] What can be a nuisance if the battery is not exhausted. There is no need to register keys again because the vehicle will not start if the immobilizer is distressed. Even if the battery is not exhausted, it does not make sense. Maybe it's not carving instead of battery or you don't realize it's over. [/ QUOTE]
buddy we showed this to a keymaker this integrated corrupted & nbsp; He said that the complete system will change. Room 250 TL :( When I asked my father, they said that we tried to install a new battery, but I did not. So I was confused ...
08.05.2020 18:13 # 4
zorvolkan
[QUOTE = dogancanguden] What can be a nuisance if the battery is not exhausted. There is no need to register keys again because the vehicle will not start if the immobilizer is distressed. Even if the battery is not exhausted, it does not make sense. Maybe it's not carving instead of battery or you are not aware that it is finished.
08.05.2020 18:13 # 5
I don `t get it? Have you placed the immobilizer on the newly built key? Which key are you operating the vehicle with?
08.05.2020 18:13 # 6
zorvolkan
[QUOTE = dogancanguden] I don't understand? Have you placed the immobilizer on the newly built key? With which key do you start the vehicle? [/ QUOTE]
yes, he installed the inside of the control in a new one. The control was not locking the doors but opening the car ...
08.05.2020 18:13 # 7
As long as you don't lose that jeep, you don't need to copy new keys. Something black about the size of a small nail. I don't understand how the keys don't work. I think an electronics engineer can do it. There is no need to give 250 lira, you will do it in the last case.
08.05.2020 18:13 # 8
zorvolkan
[QUOTE = dogancanguden] No need to copy new keys unless you lose that jeep. Something black about the size of a small nail. I don't understand how the keys don't work. I think an electronics engineer can do it. No need to give 250 pounds, you will do it in the last case. [/ QUOTE]
okay, thank you for your help. I will go to an electronics store with the chip inside the remote and the key. I hope the problem is solved ...
08.05.2020 18:13 # 9
As I said, don't lose the little black piece.
08.05.2020 18:13 # 10
zorvolkan
[QUOTE = dogancanguden] As I said, never lose the little black piece. [/ QUOTE]
okay buddy ...
08.05.2020 18:13 # 11
bayenglisher
Dear friend, change the key of the key ... if you think it is not over, first put the key in the ignition and then hold the first key for 3-4 seconds ... so you can adapt to the key section in the user manual.
