PEUGEOT 307 Clutch
08.05.2020 16:06 # 1
tolgap28
or friends I have peugeot 307 hdi. My car's clutch was very fast, I went to the mechanic, let's change the clutch set, it would be so soft, we did not change it. What are you talking about ??
08.05.2020 16:06 # 2
metin
Let's update the profile of tolga bi according to him, maybe we will give you expert advice, but it is not clear where you attended the forum, you should fill all of them in your profile.
& nbsp;
It will be better if you write the model of your vehicle, type of fuel, equipment package, engine volume.
08.05.2020 16:06 # 3
I use it exactly like 307 hdi.
08.05.2020 16:06 # 4
tolgap28
okay admin;) I am waiting for your answers now: /
08.05.2020 16:06 # 5
Are you sure they use the original item? & Nbsp;
08.05.2020 16:06 # 6
tolgap28
How can I be sure if they say so?
08.05.2020 16:06 # 7
[QUOTE = tolgap28] How can I be sure if they say so? [/ QUOTE]
you can not. It is a little difficult to understand in the water situation, you could look in the box before you put it on. It seems to me that the pressure plate is hard. Did they change that?
koliva 2011-09-12 15:50:12
08.05.2020 16:06 # 8
tolgap28
brother, I did not ask, but these are not diols, is there such a possibility that it does not soften?
08.05.2020 16:06 # 9
[QUOTE = tolgap28] brother, I did not ask, but this is not possible diols, is there such a possibility that it does not soften? [/ QUOTE]
I'm sorry I have no exact knowledge of this issue, I would not like to provide false information. Other friends will help.
08.05.2020 16:06 # 10
sahin-peugeot
& nbsp;
& nbsp;
You can't be sure if you didn't go to the track and see it with your own eyes,
08.05.2020 16:06 # 11
inceyasar
I changed the printing pad, but I don't know if it is from our cars.
08.05.2020 16:06 # 12
tolgap28
Or will I use this clutch, this clutch will not soften such an insoluble case ???
08.05.2020 16:06 # 13
I also changed the Printing Pad and set Şahin Peugeot Murat from my brother and when I first pressed my clutch, the clutch went to the bottom with the touch of my foot. So it was soft. This stiffness is really strange. Be the friends, do not leave when your vehicle is in service. I do not trust these private or authorized services ...
08.05.2020 16:06 # 14
okan77
I need to be soft, I have changed the fork or something ...
08.05.2020 16:06 # 15
metin
I think the original piece may not have been used.
& nbsp;
because even though it is the same brand, it can also produce as a subsidiary industry since it produces specially for peugeot.
& nbsp;
, for example, the spark plug that bosch sells to the market and the spark plug it produces for peugeot. the master brings you bocsh spark plug and stop the original bosch buda bocsh says you think you are original. The important thing is the box. If there are no expressions like peugeot - citroen in its box / bag, it is not original. They may be identical in appearance, their production sites may be the same, but their quality is different, just as in this clutch system.
08.05.2020 16:06 # 16
tolgap28
they did not look, then they changed the fork on it, I guess it does not soften this way:
08.05.2020 16:06 # 17
metin
Take a look, this is the original box below that is original. By comparing your price, you can compare whether it was originally attached.
& nbsp;
08.05.2020 16:06 # 18
tolgap28
I asked the original diolar man dioki you make me do it somewhere else I will give your money so ambitious talking
08.05.2020 16:06 # 19
metin
[QUOTE = tolgap28] I asked the original diolar man dioki, make me do it somewhere else, I'll give it your money so ambitiously speaking so [/ QUOTE]
& nbsp;
do it for you then,
& nbsp;
get into your car first, see the stiffness of the clutch (:
& nbsp;
, then get the original and show it again and see the difference in your own money. :
& nbsp;
you are not satisfied with the clutch anyway, you will be working elsewhere and then it will be obvious.
