Peugeot 307 cd player problem
08.05.2020 14:16 # 1
I am a stranger to the Peugeot 307, I bought this car, there is a 5-cd player in the car yesterday, I installed a CD on the 1st grille, it did not write anything about the CD on the radio screen, it continued to play the same radio, then I put another CD on the 2nd grille, it was the same, I said I would take it out if there were no CDs. I couldn't find out what key to get out of it. I would be very happy if you helped this topic. Thanks in advance ... Regards
08.05.2020 14:16 # 2
bulent 77
It is necessary to long press the number with the CD inserted. CD changer may cause problems when inserting non-original CDs. This is the most common problem in 307.
08.05.2020 14:16 # 3
thanks a lot for your help
08.05.2020 14:16 # 4
pug307_26
Do not perceive it as a problem if you can not direct the cd changere tape with the src button. cd cahnger chooses the cd. Göz Kırpma
08.05.2020 14:16 # 5
okan77
And burn the cd at the lowest speed ... if the mechanism is ok, it will read it.
