Peugeot 307 can help
08.05.2020 18:52 # 1
E.B
friends peugeot 307 I have air conditioning problem in my car, in short, this is the same as in this link
http://forum.peugeotturkey.com/forum_posts.asp?tıd=23750
The situation is that I can not find the transistors in the first photo there because I am in Cyprus.
Do not have the money to send me one of mountaineering shipped to bilicek in this forum I duruo TRNC air from turkey sogugo mortal remains bakmadig provided no no ... I'm sormadig
I asked the service that the residence is complete 80 euro I don't want to give :(
08.05.2020 18:52 # 2
raconcu
My brother firstly hello. I'm an electronic technician. I saw the transistor in the link you provided. IRF type mosfet power transistors are generally used in such motor starting applications. In one of my university homework assignments, I used the IRF as a monster-like transistor. Its advantages are low resistance, high temperature operation, very fast switching etc. etc. My advice to you is to ask another mosfet transistor with its features instead of irf3205, ask the electronicsmen already in the line you gave, the guy used another mosfet power transistor with almost the same features. Normally it worked without any problems.
the raconc 2014-11-08 23:19:11
08.05.2020 18:52 # 3
E.B
Thank you, the information you provided is super really, I think this is only the death, I can not find a place anyway, I say I go to the wrong places, I go to the electricians.
08.05.2020 18:52 # 4
raconcu
You are going to the wrong place, brother, you have to go to places that sell electronic equipment. Good luck with.
IRF3205 sells the following companies. I recommend you to contact.
the raconc 2014-11-10 09:52:13
08.05.2020 18:52 # 5
E.B
It is a small thing but it used to be said that the place where I did not go is not so much today. I realized that there is no place in this Cyprus selling this !!
I have sent this message to people who have found the solution that has solved this issue before. It is very cheap for you to help. I will send your money.
08.05.2020 18:52 # 6
okan77
Bunlarda benim yaptığım işlemde çektiğim resimler... If the air conditioner stops blowing after a certain minute after turning it on, at least I will have a suggestion that I believe it will handle you until I find the relevant transistor or module that I did in the summer.
If your hand is prone to these things, I recommend you; At the bottom of the driver, you will remove the sockets and reach the fan motor, by pulling the fan towards you by doing half left or right ... there is a screw on the back of the fan motor ... unscrew the motor from the boiler ... you will reach the module with a gray cover on top. You just need to remove that gray cap ... and then you go back to the same installation ... I got my air conditioner with this application in the summer ... there are a lot of 307 users solving the problem in this way ... Good to try ... there is detail ... Brake sensor etc. You will have to take the motor out of its socket to remove the motor easily ... You do not need to use brute force while doing these gentle gentle :)
okan77 2014-11-11 10:09:15
08.05.2020 18:52 # 7
E.B
Thank you very much for your summer, I have an electrician doing this work for me, I will try it tomorrow, it is unbelievable glad I am :)
08.05.2020 18:52 # 8
okan77
I wondered if you reached the solution.
