peugeot 307 bsi changed car still not working
08.05.2020 17:06 # 1
kartal32
friends, when I paused with my car, the wipers started to work on my own km reset, I pulled the car aside and stopped but the wipers worked for a while, then all the indicators were lit and the car pufff no sound , the starter is not working. I took it to the authorized service bsi burned changed but the car still does not work there is no reaction when turning the ignition , the master starter dynamo in the service said no electricity, we are investigating the problem but said we cannot find it "C Can you write an answer with knowledge about it
08.05.2020 17:06 # 2
kartal32
car 307 1.6 hdi 2006 model at 94 thousand
& nbsp;
according to the master;
1- battery is full
2- starter motor is running
3- There is nothing on the engine
4- can be in the installation
5- bsi has changed but the encodings are okay the keys
6- the problem is caused by the electronics.
08.05.2020 17:06 # 3
kaan__
it is good to plug in and try a new com2000
08.05.2020 17:06 # 4
xpyhre
The contact cable is burned (defective) or there may be a problem in the fuse box. Electricity does not go, so the starter is not making it. The problem is electrical. Also, if bsi is burned, there may be a burn in the harnesses going to bsi. does not supply electricity to the brain
xpyhre 2012-10-23 02:44:59
08.05.2020 17:06 # 5
kartal32
The new electrical system of the car came back, but we turn the ignition, there is no click, the master next to the battery in the service changed the part inside the box, again, nothing, why is it so hard to detect if the cable is burned? I wonder if it was the money or the problem caused by it. There was no warning lamp before. It was a clean car that was built 1 month ago.
08.05.2020 17:06 # 6
spearo
There is a fuse in the fuse board that cuts the electricity used from certain main arteries when the car seat is stored in this normal use mode;)
08.05.2020 17:06 # 7
kartal32
Thanks for the cvp, the service has solved the job today, the reason is simple electrical malfunction.
08.05.2020 17:06 # 8
reco68
slm eagle 32 i have the same problem i have been lying in my car for 3 days could not solve exactly where was your problem i would be glad if you write
