Peugeot 307 Battery Starter Problem
08.05.2020 19:38 # 1
Hagen
Hello everyone, I will explain my problem for a long time.
Vehicle: Peugeot 307 1.6 XS
Model: 2002
Yesterday I traveled with my vehicle in a very nice way. When I parked the vehicle in front of my house, I left the rear fog open, or the tape remained open, the battery was reset.
I got up in the morning The doors were locked. The vehicle barely opened the doors. I got in the car, turned the ignition, starter motor tried its chance, but the futile battery is empty.
Afterwards, I removed the battery completely, removed it from the vehicle, charged it and put it back in the same way.
Then I realized that My Key Is Not Working and the Red lamp was flashing in the Central Lock system. Anyway, I said it will be okay and I passed.
I inserted the key into the ignition, I turned the ignition, the starter motor turns the main motor, but the engine does not work, as if there is no fuel, but the tank is full
I tried key syncrosification methods. I turned the ignition 1 click and pressed the lock button for 10 seconds
Then when I try to lock the doors from the Key, ECONOMY MODE ACTIVE says only. does not lock the doors.
What should I do. why does it. I'm going to freak out. I have a ton of work tomorrow, are there any friends who can help?
08.05.2020 19:38 # 2
ARDADOGAN
I think if the battery is full, I think the saddle will take off the pole and re-insert it but wait for a 5 10 seconds so it will recover.
08.05.2020 19:38 # 3
Hagen
I tried a lot .. it does not happen the vehicle has reset myself nappe bidet Lock light flashes quickly without stopping
08.05.2020 19:38 # 4
talip206
If you have a spare key, try it.
08.05.2020 19:38 # 5
Hagen
Exactly, I suspect him, aspire, but he doesn't recognize the key. Red LED light is on from time to time, slowly and slowly, without stopping at the central lock.
08.05.2020 19:38 # 6
talip206
http://www.google.com.tr/url?q=http://public.servicebox.peugeot.com/ddb/modeles/4008/4008_4008/ed02-12/tr_tr/contenu/ap-4008_02_2012_tr.pdf&sa= the & ved = 0ahukewib7pxpvuvkahvccswkhqc5clcqfggnmay & uSG = afqjcnhfh7q to-uyrrv6ınlqzbc96qqcaug
08.05.2020 19:38 # 7
Hagen
[QUOTE = talip206] http://www.google.com.tr/url?q=http://public.servicebox.peugeot.com/ddb/modeles/4008/4008_4008/ed02-12/tr_tr/contenu/ap -4008_02_2012_tr.pdf & sa = U & ved = 0ahukewib7pxpvuvkahvccswkhqc5clcqfggnmay & usg = afqjcnhfh7q a-uyrrv6ınlqzbc96qqcaug [/ QUOTE]
Mr. Talip, my vehicle is 307.
can you tell me what you mean?
or should I read the 350 page PDF?
08.05.2020 19:38 # 8
talip206
I couldn't look at it because there was a problem on the phone, but when I wrote 307 lock light fast flashing in google, there was information about the fast flashing of the light in the footer so I copied the link completely. It says the reason in it, but I could not look at the page. But when you open the pdf, if you search by pressing ctrl + F, I think it will come out
08.05.2020 19:38 # 9
Hagen
I read in the evening, teacher, but there is no information, thank you very much for your interest and interest in the pdf you have posted.
My problem still continues
08.05.2020 19:38 # 10
The problem is most likely about the key, my teacher immo does not recognize the car, so the car will start and the car will not start. If someone you know has a car, disconnect the battery and try it. if there is no possibility, you will have to get a key. cost between 150-250 TL
08.05.2020 19:38 # 11
Hagen
[QUOTE = sonerkyl] the problem is probably about the key my teacher immo does not recognize the car so the car will start and the car will not start. If someone you know has a car, disconnect the battery and try it. if there is no possibility, you will have to get a key. cost between 150-250 TL [/ QUOTE]
I think I introduced the soner key, but now when I lock or open it, ECONOMY MODE ACTIVE says that the lock light is blinking when all the doors and the trunk are open
