Peugeot 307 battery dead, doors won't open
12.12.2022 15:45 # 1
sevgili_arabam
I've been following the forum for months, but luckily today. I have a 307 cc vehicle that I love very much. CryThe battery is dead and unfortunately I can't open the doors from remote and lock. Therefore, I can not give reinforcements from the hood. Is there anyone have an idea? thanks
14.12.2022 04:18 # 2
antipollution
My brother, 3 years ago, my battery died in the morning, I think I left the tape on at night. But there was enough of God to open the doors. After the reinforcement.. When I experienced this incident, I came to my senses. I tried to see what I would do if it was completely finished, if the doors did not open, would I open it with the key. It wouldn't even go into the keyhole, let alone with the key. He had made a pass. I thought I should have this fixed as it could happen to me again. I tried again and again by spraying WD40 rust remover on the key tip and all rust was removed in about 15 minutes and the driver's door was opened. So wet the tip of the key with WD40 and feed it well.
14.12.2022 10:17 # 3
sevgili_arabam
dude, the key goes in and turns easily, but it doesn't open... you showed interest and wrote, thank you very much
15.12.2022 01:59 # 4
antipollution
the worst driver's door has to open, you think it's turning all the way around, but it's not actually turning. It's half turning. Try wd40, be sure to squeeze the key, wait a little, drip into the lock, and after a few minutes, the rust will be removed and opened. If this method does not work, you will need to seek help. There will be situations such as breaking the glass, lifting the car and unlocking the hood with intervention from below.
15.12.2022 02:01 # 5
antipollution
Look, I found a solution like this, I'm pasting it directly on the net here,
vd40 or something, but it didn't help. Then I removed one of the license plate lights and energized the bulb holder with the help of the battery cable from the friend's car. I connected the positive wire to the bulb holder and the negative wire to the exhaust iron. In this way, electricity came to the vehicle and I was able to open the doors, then I was able to start my vehicle by charging my vehicle's battery. I hope it will be a guide for friends who have experienced such a situation.
15.12.2022 02:16 # 6
sevgili_arabam
very interesting joke
if I knew it would work, I would even break the headlight :) I would go buy a new one, it would turn yellow anyway... let me research it, it's a very creative idea bro, thanks
