Hello, sir. The oil level may be low. The solenoid valves may be faulty. The problem with overheating could also be due to what I mentioned. Unfortunately, the AL4 transmission is problematic. The transmission oil cooler may be clogged. These transmissions were overhauled in 2006, and there was some improvement. The oil coolers were enlarged. The oil and two main solenoids are being replaced, and there's a 50% chance of improvement, but definitely have the oil cooler checked. Also, don't forget to check the fault codes.
