Peugeot 307 automatic gear problem
08.05.2020 19:53 # 1
Uysal
Hi everyone, friends
I have a problem with my car 307 automatic gear "D" while driving, I pull to the tiptoton, but the D still appears on the display and my car's traction power drops. It becomes normal when I run and run it again, but sometimes it gives the same problem again
08.05.2020 19:53 # 2
OguzhanKucuk61
Sensitive. It is unbalanced. Often we had trouble getting stuck in our old 206. While the contact was waiting open, it didn't come when I took it to p and tried to pull it to d to go after a while. Either he came physically and was still staying at p. If you are going to get an automatic car, Honda oguzhankucuk61 2016-06-27 02:17:55
08.05.2020 19:53 # 3
talip206
[QUOTE = Submissive] Priority hello everyone, friends
I have a problem with my car 307 automatic gear "D" while driving, I pull to the tiptoton, but the D still appears on the display and my car's traction power drops. It becomes normal that I run and run it again, but sometimes it gives the same problem again when going [/ QUOTE]
What should be looked at the shift position switch. If it does not cause any trouble without any intervention, it is very likely that the shift position switch should be checked. There is another problem if the upshift in automatic mode does not downshift, falls out of traction, if the sport and snow mode light is flashing. (solenoid etc.)
08.05.2020 19:53 # 4
Uysal
The car falls out of traction, lifts itself hard and started doing it often
08.05.2020 19:53 # 5
serkanay55
Have you tried to reset the vehicle, take the pole and plug into the brain, wait five minutes, and if the plug doesn't fix, look at different places
08.05.2020 19:53 # 6
Uysal
Yes yesterday we tried electrician master waited, but it did not help
