Peugeot 307 Automatic Gear Problem
19.05.2020 17:57 # 1
Rayovac
Hello, I bought a Peugeot 307 Automatic car. There was very little sweating in the gearbox (no dripping), I used it for 3 months, and I did not have any problems. But after 1 liter of extra oil, problems started. The car was a few times, although it was at D, I was giving gas, it was not going, then it was going with a hard hitting. Sometimes the transmission fails, s_ * marks appear on the screen, I turn off the contact and run it again. Have you ever had these problems before? If there is an automatic transmission master on the European side of Istanbul, I would be glad if he writes a comment.
19.05.2020 18:18 # 2
muzzy35
Man, the transmission oil size is delicate, you can not add from the head, I think without using too much, find a smart gearbox and drain it completely and put it to the full extent (I do not remember exactly 4 liters) it will damage the excess oil. -19 18:19:25
23.05.2020 15:09 # 3
EmSul
What oil did they put in the gearbox? Mobil atf lt71141 should be put in. It is not done in adding oil, so what did you do like that? then, when the vehicle is working in the N position, the first plug is opened and the excess is removed until the oil flows thinly. If you do not tamper with it, I'll direct you to the master master EmSul2020-05-23 15:23:01
24.05.2020 10:58 # 4
Red
You did not make a mistake by adding transmission oil because you do not know how old the oil was before you knew how old it was before you know how old the oil was in years and it works in harmony with the gears, but for the new oil you put in, the article says that the automatic gear fault is damn I bought it in the press 307 2003 automatically 6 months I got it last 6 months I spent 7000 pounds in the end I sold it to the master, nobody is a professional of this job, not a professional pegout service. pejo service asked 38000 lira to fix the defects, make your account, have a nice day
25.05.2020 15:28 # 5
EmSul
If you cannot find the master, you will be so damned, the authorized service does not understand at all, they are even more terrible 7000 lira zero-crate gearbox is installed, also there is no problem that the master master could not solve in al4
25.05.2020 17:11 # 6
Red
I did not spend 7000 liras on sanjuman, I generally spent on the car. I do not mention the fact that those who used the contempt from the old 307s do not come, al4 transmission does not change the fact that it does not pay 5 money. I am using Suann 508 1.6 hdi, I am very pleased, my advice from the sanjuman and the car is to get rid of the car, the expense of the vehicle will take something on it and buy another vehicle
26.05.2020 02:00 # 7
BATUHNn
Sir, I had the same problem with me, I immediately replaced it with the honeycomb of a top model and I checked the pump.
04.02.2021 21:52 # 8
Nurse3439
Hello
I have a 2006 model 1.6 xt 307 with automatic transmission. I bought it in February last year.
I do not understand the car very well, let me state it first.
About 3 months until the engine of the car is warmed up. It locks the 3rd gear, and when I switch it to manual mode, only D is displayed. Snow and sports mode does not warn. When I pull it to the right, turn off the ignition and turn it on again, my problem was over, but for the last 3 days, it has not improved on it either. Since there was no heavy traffic and traffic lights where I live, I had no problems with the other gears. Only once did I do a lot of stop and go, then when I was going from 1 to 2, someone from the back made a continuous knock as if it had been hit. The road I used to go to work is a bit too ramp and now it started to strike from the back while climbing. I took it to the nearest pejo service, we do not understand the automatic transmission, but they looked at the error code to learn what it was saying, "The pressure regulation advice is not characterized". He puts the speed forward and brings it back to normal. For example, I go with 50 to 60, the speed suddenly becomes 5000, the engine screams, but if I step on the gas, it does not accelerate, then it returns to its normal speed and accelerates itself. I bought gas from a place that I do not trust much, I don't know if it has anything to do with it.
I will go to Istanbul next week, can you suggest a good master who can solve this problem. Thank you very much for your help in advance.
(You have such a problem for 3 months, you will ask why you waited, I know I am a healthcare staff and our leave was closed for a certain reason, it was just opened. I had to leave the vehicle for at least 3 days, but I could only go to work, my own vehicle
Nurse3439 2021-02-04 21:56:23
04.02.2021 22:14 # 9
muzzy35
First of all, get well soon.
04.02.2021 22:27 # 10
Nurse3439
Was it the same problem for you?
Also, do I have a phone number or full address that I can reach :)
04.02.2021 22:49 # 11
muzzy35
The master summer, who sold a gardener on the internet, comes out directly
Not exactly, mine was a little better;)
06.04.2022 09:20 # 12
Emn1907
Hello friends,
There is an automatic transmission problem in my 2003 model 307 vehicle. I get an automatic transmission error, when shifting from 1st gear to 2nd gear, it takes the vehicle to neutral and accelerates as if it gives the intermediate gas, then switches to two. The car has little to no traction in low gears. It gets worse, especially when the car warms up. 2 months ago, they changed an electronic device called the gear brain, I gave 1.000 TL. Now a master said, change the valves, they'll wrap up a bit. Another master says that this issue cannot be solved with valves, it needs revision. I got a price for the revision and they made a price between 13.000 TL and 16.000 TL. I don't know what to do anymore. Location Ankara.
03.06.2022 10:45 # 13
ralf_fb
First of all, get well soon, I don't know if it's related to your situation, but there was a problem with my 307 sw automatic vehicle, when the vehicle was in motion, for example, when I stopped at the lights, it wouldn't move when I stepped on the gas, then suddenly the gear was engaged with a hard knock and started to take off, I asked many transmission drivers. He said 6 months warranty, then I said what will happen if it repeats, he said revision again :) They are like a joke, at the same time, my vehicle started not to work in P, it was only working in N, and when it started not working in N over time, the transmission man said that the gear position switch (contactor) might be defective. I got a price for this part, then I had a Peugeot electrician in Istanbul Maslak Industry replace this part for 700 liras, now both that non-working problem I mentioned and that hard knocking problem on take off after stopping have completely disappeared, thank goodness and it has been about 1 year since I had no problems, Considering the possibility of being from that piece I can recommend you to have it checked and if you give a price that won't upset you.
I hope your problem will be fixed with the most inexpensive solution.
15.09.2022 19:02 # 14
cnaykut
Master, I was having the same problem as in the first message. Today, when you saw this message, I also changed the piece you said. The car ran properly for an hour. Then he did it again.
The gearbox has also seen a revision in its previous owner. But there was an oil leak etc. I changed the oil yesterday with the appropriate oil. The fan is also connected to the 2nd stage. I've ruled out other possibilities as well, as you can see. This was the only thing left. It didn't happen again. I still use the car in snow mode.
20.09.2022 10:10 # 15
ralf_fb
up
20.09.2022 10:15 # 16
ralf_fb
hello teacher, I am really upset that the problem has not been fixed, it is also sad to have cost you with the information I have given, but I also wanted to ask because I was wondering, were you there when the part was changed? During this part replacement, I saw that they made adjustments by using the buzzer of the electronic measuring instrument while making their adjustments, later on, when this topic was mentioned again on a page, some masters said that they were unaware of this setting. Was a similar or different adjustment made to your part, or the part was fixed and the process was terminated? is it?
20.09.2022 10:19 # 17
cnaykut
Hello. Is it Estağfurullah? You know, we are trying every way to solve the problem. It's not an expense. After all, nothing went into the air. Part of our vehicle has been renewed. Now, at least, that piece of possibility doesn't remain in my mind.
They made the setting you said. But you said that there should be a sound in the r and d positions of the measuring device, and no sound should be heard in the n position. The master also says that it must be the opposite. When the sound is heard in the N position, the assembly is completed. He said that the device should not sit in the R and D positions.
I think I need to focus more on the cooling system.
20.09.2022 10:49 # 18
ralf_fb
I wrote on the other topic, I'll write it here, I'm in Istanbul, I had the number of the master in maslak industry, but the phone was faulty, I didn't save it in the google directory, check the number on the new phone. I searched but couldn't find it. If I can reach you, I will send you his number or if you are in Istanbul, I can direct you to him. Believe me, I don't know if this setting is correct, I don't know what the master told me when I asked him, maybe he told me wrong, maybe I misunderstood, I don't know but I'm sure he said it this way, other than that, I had the radio and hoses completely cleaned before this part was changed, but my problem was after this part was changed. then it was fixed.
