Peugeot 307 automatic gear fault error
08.05.2020 19:37 # 1
besyobora
Friends I have a 2004 / model peugeot 307 automatic gear car last week, it showed an automatic gear fault error on the screen and something happened to the vehicle's speed at that moment. I stopped it and started it again, but the same problem continued. Goturdum electro valves changed transmission oil changed 600 TL in total. The master who made it said that the vehicle could enter the revision of the gearbox in the future.
08.05.2020 19:37 # 2
I hope, honestly, I do not repeat your problem. In 206 and 307, a chronic problem happens to many automatic vehicle users. I hope everything will happen to you. good forums
08.05.2020 19:37 # 3
RedHotRyder
Hello first of all, the same situation has been in my car for a while. Especially in the winter season when the vehicle's engine temperature is low, when I set off without heating the engine, there is a very hard transition sound from the first 2-5km gears, the engine's rpm changes officially :) and it gives a warning in written and audible form on the screen. When I stop the car safely in a safe place and start it again, the warning goes off the screen and at the same time the engine gets hot, I don't get any more errors until the engine cools down again during the day. I think that the gearbox oil cannot shift gears because it is cold. Frankly, I do not think this is a situation that I need to have it repaired, maybe I think I will not take it again when I change the gearbox oil during routine oil change. For those who have this problem, maybe I will share the change after the oil change.
