peugeot 307 automatic gear error
08.05.2020 19:01 # 1
samet33
Hello there. my peugeot 307 205 model has automatic transmission. In the cold, especially under 5 degrees, the gears were knocking, the first five minutes passed until it warmed up, recently I was heating the car at idle for 3 minutes, but after doing this, it sounds 4-5 km later and it says an auto gear error and when it goes between 60-90, it sounds like a plug from the vehicle. And when I press the gas, the car is not going, I have to stop and open again authorized service recommended valve replacement and oil change. do you think it will get better after you have done this?
08.05.2020 19:01 # 2
denizci33
I hope that it will recover, my teacher .. after all, the oil changes first, then the solenoid .. then they call it a revision .. you continue in this order ..
08.05.2020 19:01 # 3
msertkol
What is the temperature of samet33? I made a complete overhaul, I changed two squares, I made 20000 km the same. I can not solve. I think maybe the gearbox can't cool down. My car is LPG.
Can you guide me if you experience improvement in repair?
Best regards.
08.05.2020 19:01 # 4
samet33
There is no problem with fervor 90 is difficult, mine has more problem with cold. When it is below 5 degrees, it does this problem. It was a maximum of 100 degrees in traffic on hot summer days. I will write it here in a few days. samet33 2015-01-24 22:09:05
08.05.2020 19:01 # 5
samet33
[QUOTE = msertkol] What is samet33 overheating? I made a complete overhaul, I changed two squares, I made 20000 km the same. I can not solve. I think maybe the gearbox can't cool down. My car is LPG.
Best regards.
I made a solenoid valve and gearbox oil change, no more knocking sounds and does not stay in high gear when going uphill, the car immediately downshifts. For now, it has not made an automatic shift error, but I have not used it yet below zero. The weather is a bit hot. Let's see what happens next.
