PEUGEOT 307 AIRBORNE LIGHT
08.05.2020 20:36 # 1
lASLAN307
Hello friends, my Peugeot 307 2006 premium car had an airbag problem 2 weeks ago I went to the service and got a new signal arm set, the horn did not work, the air light was on, the headlights were stuck, the problem was fixed, but when I parked my car and started my car, the air light was burned again I ran it, the problem has not been corrected, my horn is working, the headlight sensor or something is wrong. Thank you in advance for your help.
08.05.2020 20:36 # 2
[QUOTE = lASLAN307] Hello friends My car Peugeot 307 2006 premium car had airbag problem 2 weeks ago I went to the service and got a new signal arm set, horn not working airbag light burned, headlights remained fixed problem, but when I parked somewhere and started my car again, the airbag was My light turned on, I turned it off, I started the car again, the problem was not resolved, my horn is running, the headlight sensor is not okay, why could this fault light be burned again? Thank you in advance for your help. [/ QUOTE]
My teacher, look at the sockets under the seat. Play with your hand will probably get better.
08.05.2020 20:36 # 3
lASLAN307
I had a little play with my driver's seat, I had it set up while sitting in the morning, but it was lit in the evening, there was 1 orange big socket under the left seat, I played it a bit, but the light did not go out, I have a situation not to delete it when I recorded the fault in your brain?
08.05.2020 20:36 # 4
Look at the fault code of the best teacher, it becomes clearer where it originates. a negligent fault may have been recorded as you said, but it is usually caused by socket connections. I think there is one more socket under the seat and one under the steering wheel, but it is necessary to remove the cover and look at it if it is not fully seated while mounting.
08.05.2020 20:36 # 5
lASLAN307
I will go to the service again.
08.05.2020 20:36 # 6
[QUOTE = lASLAN307] I will go back to the service. They put the Sinya arm set, they said if there was a malfunction, I will write the result here [/ QUOTE]
Was my most beautiful teacher stuck in the authorized service?
08.05.2020 20:36 # 7
lASLAN307
yes, it was installed in the authorized service arm signal set was even more expensive in the arm set of models over 2005 model, it gave 1500 TL price. When the service gives the same price in the industry, it is more reasonable to have it installed in the service. Confused
08.05.2020 20:36 # 8
the prices have flown a lot, the ones with the headlight wiper sensor, 700 TL my teacher, the ones in the industry have given you a very high price. the authorized service solves the problem. of course they don't want extra money.
08.05.2020 20:36 # 9
lASLAN307
No Master, there is no ESP on the arm in that link, it is probably for the old case. I gave my vehicle to Adana Adana, I gave it to Istanbul, I gave it to Ankara, the result is 1500 TL. After 2005, the VALEO brand did not produce the signal sleeve set. Most of the signal sleeve set sold as original in the market, Valeo produces the signal sleeve set. The reason for the fact that the make-up case was low in the market did not come from original France. It did not write Made in France on VALEO.
08.05.2020 20:36 # 10
lASLAN307
In the meantime, we tried to find it on the arm. At first, the vehicle did not even work. I could not find the arm signal set in the big industry in Gaziantep.
08.05.2020 20:36 # 11
lASLAN307
By the way, I don't think these problems belong only to peugeot. While the forum followers showed the airbag reel in the industry for the first time, the master was standing inside the 2009 model Renault Laguna. The airbag tie was broken in him. You said okay, the master said health to your hand, and I am changing my arm suit completely? I said exactly, I said how much yours was the price I received was 4500 TL. And the man went to the service and changed his sleeves.
08.05.2020 20:36 # 12
hmm I understand my brother anyway now strange sleeves generally slept but for the cars with esp. Airbag winding problem only occurs in many vehicles in peugeot. When you look at the industry, you have done it again.
08.05.2020 20:36 # 13
xmen
As my soner premiums are ESPs, different arms are actually the same, but there is ESP feature on the arm, so I know that I had the same problem with different prices. Two years ago the service had said the price of 1100 TL
08.05.2020 20:36 # 14
[QUOTE = xmen] Soner teacher is a different arm because the premium is ESP, it is actually the same, but there is ESP feature on the arm, so I know that I had the same problem with different prices. Two years ago, the service had said the price of 1100 TL [/ QUOTE]
Thank you bro we learned. Thumbs Up
