Peugeot 307 Airbag Problem and minor problems
08.05.2020 17:46 # 1
joshuagold
Hello friends.
About 6 months ago, I am very happy to buy Peugeot 307 and join you. My vehicle is 2003 307 XR model with LPG. I have some modifications I want to make and a few problems.
* First of all, when I connect my car to the computer with peugeot planet 2000, it does not see the brain of the car. When I start the car, it writes airbag fault and passenger airbag deactive writings in about 10 seconds. What can I do about it. I looked at the socket under the seat, there is no problem, a mechanic I talked to said that it would not be from com2000, it might be a problem caused by the airbag brain. But I want to solve this problem in the most reasonable way. In the meantime, I can do a lot of repairs, and I am skilled in this regard.
*2nd. As I do not know if there is a trip computer in the standard equipment of my vehicle, the vehicle has a 3-line display and a button on the wiper arm. I want to activate this trip computer.
* 3 I want to install cruise control on my vehicle. What do I need to do about this?
* 4. As I run the air conditioner in my car, there is no smell, but when I turn off the air conditioner and run a fan, there is a strange smell. I called the pollen filter. How can I solve this problem.
Thank you very much to the friends who have already helped me, I want to solve these problems as soon as possible before going on vacation.
joshuagold 2013-07-10 14:11:19
08.05.2020 17:46 # 2
qqyyxx
When the pollen filter opens the hood, you remove the sound insulation felt on the passenger's side. There is a rectangular plastic cover holder on the chest and you are already pulling it off. You can search and find other topics related to topics.
08.05.2020 17:46 # 3
joshuagold
I could not find the section about the airbag problem on the site, usually everyone's com2000 faulty my car does not see the airbag brain.
08.05.2020 17:46 # 4
error
I know that you have a trip computer in valla car. You can also connect to pp pc settings. Open the cover "right on the fuse box" on the brake operator for cc. You can see how many sensors there are and how many wires can be spoken according to the result of this, but cc can also be applied to the likely tool.
There is a red key slot on the center console above the passenger airbag handbrake, insert the ignition key and turn pessenger error "which is not a mistake" disappears, but if you get a pessenger fault like the other error then know that the vehicle has received an accident from the front and the front airbags are opened from you. it means that the previous user has not renewed the airbags ...
make it easy, pay attention to the air bag, first of all, focus on the airbag problem ....
08.05.2020 17:46 # 5
ismailkaya
the road computer is working, it says that the 3-line division airbag fault and passenger airbag deactive writings says that it is active to write, of course, if the fault indicator is not on the speed indicator, it is normal to write, for example, when the vehicle is in very idle motion, it warns you to pull the handbrake km-temperature-the road you will go - the fuel shows that the trip computer is running
08.05.2020 17:46 # 6
ismailkaya
You are 307 more good by the way
08.05.2020 17:46 # 7
fatihgg
1-com2000 may be faulty, get support from a mechanic dealing with airbag work is an important issue,
There is no 2-way computer, there are 3 lines of screen, but we cannot see the information. There was a button making on his arm, but there was no application in 307, I think there was a friend who did not make it when he put it in his tent.
The 3-brake pad will be 4-wire, 2 will be pulled out of the brain, and also check if there is a left-hand rectification on the left side.
You need to replace the 4-pollen filter.
Good luck with.
08.05.2020 17:46 # 8
joshuagold
Guys, first of all, thank you very much for the answers.
I found the pollen filter I will replace it today. (Thanks qqyyxx)
For CC, I will look at what you say today, I will let you know from the forum (thanks errör and fatihgg)
I think there is a trip computer that I will try to open from pp2000 for the trip computer. There is an arrow on the arm to indicate that there is a key.
For the airbag, the vehicle has no accidents before, there are only 1.5 parts of the right rear fender and the paint on the door. The key behind the handbrake does not correct my passenger airbag foult alert, so the airbag problem is not related to the key, but I will disable the key and try to connect it flat. airbag does not see his brain. If the problem is not solved, is there a good place you know on the Anatolian side of Istanbul? the price is affordable.
joshuagold 2013-07-10 12:54:44
08.05.2020 17:46 # 9
joshuagold
[QUOTE = ismailkaya] the road computer is working , the writer says that the 3-line division airbag fault and passenger airbag deactive writer says that it is active to write, of course, if the fault indicator is not on the speed indicator, it is normal to write it, for example, it warns the handbrake when the car is in very slow motion km- temperature - the road to go - the fuel shows that the trip computer is working [/ QUOTE]
I didn't understand what you mean here because my trip computer is not working. No warning lights also appear on the indicator lamps. Can you explain in more detail and clearly?
08.05.2020 17:46 # 10
emin15
Find out the reason why the airbag brain is not seen by the computer at the authorized service.
