Peugeot 307 Air Conditioning Not Working
08.05.2020 21:15 # 1
Boz_Dem
Hello friends,
I just joined you. I have a 2002 model 307 1.6 Gasoline / LPG OV vehicle. I just bought the vehicle.
My problem is that the air conditioner is not working. AC light is on but not cooling.
As it is known, I did not go to the authorized service because it is LPG. As far as I researched in the forum, it has been a problem solver with brain updating. But I couldn't do this because the service did not buy LPG vehicles.
I showed it to a master I know well in Istanbul maslak industry. the brain is not exiting. He said resetting is necessary. He said he will serve him.
Now what should I do in this situation?
If there is a friend who has an idea, I would be happy if it helps. Is there a master you can suggest.
As a note, the master said something on the computer as the brain appeared as 206. Is this possible?
08.05.2020 21:15 # 2
I don't think it will have 206 brains, but we have to look at it with original software. also according to the bs part code on the vehicle. I say the teacher met with here in a http://birlikotoservis.com/
08.05.2020 21:15 # 3
Boz_Dem
Hello,
Thanks for the answer.
When I search for the BSI Part code, it turns out to be 307. I have no hesitation in this.
When I press the AC button that is told to me, the command comes to the brain, and the command to the compressor does not go from the brain. They said you can solve this with software update.
Now if I do BSI reset without software update, can I solve this or will everything be worse? Confused
I will also call and ask for the place you say. Thanks.
08.05.2020 21:15 # 4
Boz_Dem
[QUOTE = sonerkyl] I don't think it will have 206 brains but we have to look at it with original software. also according to the bs part code on the vehicle. I would like to talk to my teacher. http://birlikotoservis.com/ [/ QUOTE]
I talked to the place you called. They redirected to another place without a master. I will go and have a look at the weekend. If I find a solution, I'll write it here. If others experience the same problem, maybe it will help.
08.05.2020 21:16 # 5
ismailkaya
There is no connection between the brain and it has either resins failure or cable socket contact. There are 307 trip computer screens, twill the screen in the middle of the console, hold the screen with both hands, remove the front nails, then remove the fingers, pull your fingers in the right corner, there are air conditioning cables and connection socket in the right corner. In whichever position it doesn't work, put it in that position and push it gently with your hand, let's see if it does it. In that area, air conditioning does not work due to socket problems.
08.05.2020 21:16 # 6
Boz_Dem
[QUOTE = ismailkaya] There is no brain or something related, it has either resinstans malfunction or cable socket contact. There are 307 trip computer screens, twill the screen in the middle of the console, hold the screen with both hands, remove the front nails, then remove the fingers, pull your fingers in the right corner, there are air conditioning cables and connection socket in the right corner. In whichever position it doesn't work, put it in that position and push it gently with your hand, let's see if it does it. In that area, air conditioning does not work due to socket problems.
First of all, thanks for the answer.
There is no problem in the fan stages of the air conditioner, 1.2.3.4. they all work smoothly. I think the resistance or cables are intact. In short, there is no problem blowing, it just does not cool. There is air conditioning gas and pressure values are normal. like there is no leak.
AC button is on but compressor does not work for cooling. I am sure there may be a minor problem, but finding a master who understands this is very difficult even in Istanbul.
I'll show you another master on Monday. Let's see the group I will inform about the result.
08.05.2020 21:16 # 7
ismailkaya
Show it to the air conditioner, not to the master.
08.05.2020 21:16 # 8
Boz_Dem
[QUOTE = ismailkaya] Show it to the air conditioner, not the master, wherever the vehicle is faulty, go to the non-master and do not pity your money [/ QUOTE]
I just called the air conditioner master who gave the car. They got in the car, gas leaks, everything is normal and correct. The car brain doesn't see the air conditioner, he said. A good master who understands the brain solves the problem, he said, "It is not something I can do," he closed. In addition, the central clit was not working. I was closing the door and opening the car. (Though it opens from a single door, all the doors are opened, though.) He said it would originate from the brain.
Now I am looking for a master who understands a good brain. If it is repairable, we will have to buy a new brain.
If I ask you a question, I will not solve the problem. No need to get zero.
Or you know a good master in Istanbul.
That air conditioner eventually cooled me off the car.
