peugeot 307 5s cd player
08.05.2020 16:24 # 1
jiyanxese
friends, my car does not play trac, mp3 and audio cd, it tries to read when I insert a cd, then gives it back and it passes to the radio. Moreover, it does not give any fault signs. The lights do not blink.
08.05.2020 16:24 # 2
albayman
I ordered a USB device. gone and gone, they're all sold on sites like here. I have a few varieties, let me write a brand
1: cadence
2: audio system
& nbsp;
I will make an application, I am thinking about painting and sharing it in the forum ...
08.05.2020 16:24 # 3
jiyanxese
There is no solution to the 5-cd player (except for the usb apparatus)
08.05.2020 16:24 # 4
efsanemurat
same problem I have in my car, I asked how many CD readers, what did they say is broken? They are chronically troubled, I am doing research.
08.05.2020 16:24 # 5
djchaos
[QUOTE = jiyanxese] my friends car does not play trac, mp3 and audio cd, it tries to read when I insert a cd, then gives it back and it passes to the radio. Also it does not give any fault sign. The lights do not blink. ? [/ QUOTE]
I think he started to choose the CD, he can take out the CD he could not read if he bought the original cd, but if the life of the cd player's laser lens reader is over, the original If you do not read cdyide, maybe you can remove it and clean the lens, there may be a cure, the lens is dirty or its life is over & nbsp;
08.05.2020 16:24 # 6
albayman
My dear forums, I think I don't give 100tl or more repair money to no avail. I ordered a usb device, & nbsp; came to my hand today. I couldn't get it installed, but hopefully tomorrow ...
& nbsp;
will remove the & nbsp; socket from the cd changer that goes to the back of the tape without any permanent changes to the original parts of the car and replace it with the usb socket. (should be made to someone who understands or should be thoroughly learned.
& nbsp;
I will let you know when I practice ...
08.05.2020 16:24 # 7
albayman
"Hug" Yes guys !!!
I just bought the pliers and a thin metal & nbsp; clothes hanger and the usb bracket down the car, so I can see if I can fuck it.
then I inserted these U-shits first into the holes in the corners of the cd changer, and the changeri came hanged back :) DIV> & nbsp;
this part is important, I just removed the changer's socket from the sockets on the back of the tape and replaced the socket of the usb apparatus. I have already inserted the CD01 CD02 ........... CD06 folders and my usb flash memory with mp3 inside the usb device. I pulled it to basma :) I pressed the release button of the tape. from there I pressed the SRC button and then the number 1 on the tape.
VEEEE: my mp3s started to play :) . tomorrow I will set a rack-shaped box instead of cd changer. then I will pierce the back of the box for the usb device cable and set the usb device inside the shelf and the back of the cable and insert it into the cd changer section where the rack is empty. I will take it to the glove compartment. I will photograph and share with you.
08.05.2020 16:24 # 8
djchaos
[QUOTE = albayman] "Hug" Yes guys !!!
I just bought a pair of pliers and a thin metal & nbsp; clothes hanger and a USB bracket, so I can see if I can do it. I cut down the metal strap with a pliers.
pliers and nbsp;
then I put these U-shits first in the holes in the corners of the cd changer and came back hanged the changeri :) :) div> & nbsp;
this section is important, I just removed the changer's socket from the sockets on the back of the tape and replaced the socket of the usb apparatus. I have already inserted the CD01 CD02 ........... CD06 folders and my usb flash memory with mp3 inside the usb device. I pulled it to basma :) I pressed the release button of the tape. then I pressed the SRC button and then the number 1 on the tape.
VEEEE: my mp3s started playing :)
& nbsp;
the apparatus is standing outside and entrusted now . tomorrow I will set a rack-shaped box instead of cd changer. then I will pierce the back of the box for the usb device cable and set the usb device inside the rack and the back of the cable and insert the rack into the empty cd changer section.
& nbsp;
I'll take it to the glove compartment.
& nbsp;
tomorrow, I hope you can & nbsp; I'll take a photo and share it with you.
& nbsp;
stop writing a CD scan.
If you take it to the electronics shop, get at least 50 TL.
08.05.2020 16:24 # 9
efsanemurat
Can you give me the link or the full name of the apparatus you bought?
08.05.2020 16:24 # 10
albayman
[QUOTE = djchaos] [QUOTE = colonel] Yes guys !!! I just bought a pair of pliers and a thin metal clothes hanger and a USB flash drive down to the car. I cut the metal hanger with pliers and got 2 pieces of U-shaped staple punch. then I put these U-buckles into the holes in the corners of the cd changer first, and I hung the changeri back. this part is important, I just removed the changer's socket from the sockets on the back of the tape and replaced the socket of the usb apparatus. I have already inserted the CD01 CD02 ........... CD06 folders and my usb flash memory with mp3 inside the usb device. I pulled it to basma :) I pressed the release button of the tape. I pressed the SRC button from there and then the number 1 button on the tape. VEEEE: My mp3s are starting to play :) The apparatus is standing outside and entrusted now. tomorrow I will set a rack-shaped box instead of cd changer. then I will pierce the back of the box for the usb device cable, set the usb device inside the rack and the back of the cable, and put it in the cd changer section where the rack is empty. Although I cannot do these things, I will take the glove box as the common method. I hope I will photograph these transactions tomorrow and share them with you. No problem with writing CDs.) [/ QUOTE] Whether you take it to electronics shop, at least 50 TL will not satisfy the taste of the hand labor you have given yourself. . so a total of 35 TL. I said, "The job you will do is simple, if you want 5-10, I can understand 35 noluyo"? Doesn't it say "if it is simple, do it yourself"? I said, "Tomorrow I will pull the car in front of his shop and make it with my own tools."
08.05.2020 16:24 # 11
albayman
[QUOTE = legendary)] Can you give me the link or the full name of the apparatus you bought? DIV> & nbsp;
There is a brand named cadence, they say better, but I wouldn't know.
When buying your vehicle, brand model year etc.
08.05.2020 16:24 # 12
106fb
pictures are welcome ...
08.05.2020 16:24 # 13
albayman
resolved here:
08.05.2020 16:24 # 14
repropark
The cd changer used for 307 is designed to be used only as an image, unfortunately its function is very weak.
