Peugeot 307 1.6 XR Automatic Gear Fault Error
23.09.2021 07:59 # 1
Muhammed_
Hello guys. I'm new to the forum. I have a Peugeot 307 1.6 XR petrol 199k vehicle. While everything was fine, the car stopped working after a while without making a few contacts. There were times when I had to crank and wait. It started working after a few turns. Why then, I traveled a lot in Kayseri industry. They found many problems. (It is worth noting that the industrial tradesmen of Kayseri - I am not saying all - are far from moral values) Some said that there is a problem with their spark plugs, some said that there is a problem in the ignition system. They said that there is a problem in BRC because he is from LGP. They would even lower the engine. Moreover, by charging a fault detection fee for these! Anyway, I went to ask a master for the last time with the idea of ​​giving up hope and getting it done in Istanbul. He was someone who focused only on Peugeot. He immediately realized that there was a problem with the fuel pump of the vehicle and we bought a new pump and the problem disappeared.
Now, the main problem is that when I went to the LPG dealer, this friend opened the part where the spark plugs are located, he worked hard there - there is oil here, this is the job of the biker and directed us. After this time, my vehicle started to give the error in question. He gives sometimes 1 sometimes 2 pieces a day. But it never exceeds 2. The error does not reset without turning it on and off. What do you think I should do? Can you recommend a really competent person around Istanbul? It also started to knock while passing from 1 to 2. I think it's because of the engine mount.
It's been a while, but I would be happy if you could help me with the problem. Good forum everyone.
23.09.2021 21:26 # 2
talip206
Istanbul Anatolian side Umraniye Kadosan Boğaziçi Automotive Ali Usta. I advise. It is useful to remove the spark plugs and coils and put them back again.
24.09.2021 07:43 # 3
Muhammed_
Thank you very much. I will definitely go.
