peugeot 307 1.6hdi not exceeding 140km on straight road |
| 08.05.2020 14:56 | # 1 |
I had poured the catalyst before it was clogged. I did not realize that I had the same problems before after the emptying, I realized that for the last 2-3 months, I did not exceed 130-140
| 08.05.2020 14:56 | # 2 |
dbmaster |
If the turbo is not a problem, the vehicle is 110 or 90? I have 110 307 hdi, I see 200 km |
| 08.05.2020 14:56 | # 3 |
1.6 hdi 110 cm |
| 08.05.2020 14:56 | # 4 |
dbmaster |
[QUOTE = ozangenc] 1.6 hdi 110 cm [/ QUOTE]My teacher, you take the vehicle and connect it to a computer. The predicted turbo is ticklish, but only the assumption does not pull up the ramp above. |
| 08.05.2020 14:56 | # 5 |
muratgulen07 |
If the turbocharger is at least 750 TL but it's not ins ... I have the same thing, I hope I didn't see the gdiyo tasting more.
| 08.05.2020 14:56 | # 6 |
dbmaster |
Just as Murat said, you can not hold the car as long as it is based on the ramp. Eating those 2.0 gasoline cars on the ramp is another pleasure. There is an 18% incline ramp.
| 08.05.2020 14:56 | # 7 |
[QUOTE = ozangenc] peugeot 307 1.6hdi 205 vehicles at 144,000 km do not exceed 130-140 on straight road, 1-2-3 gears have 30% shooting problem, vehicle sees 130-140 in 4th gear and I shift into 5th gear at the same speed continue to change gears and accelerate remains the same in 5th gear waiting for your help I had poured the catalyst before it was clogged. I did not realize that I had the same problems before after the emptying, I realized that for the last 2-3 months, I did not exceed 130-140 [/ QUOTE] sell it, get 106 quick 190 will go even harder in a single breath :)
| 08.05.2020 14:56 | # 8 |
dbmaster |
[QUOTE = 26NT023] [QUOTE = ozangenc] peugeot 307 1.6hdi 205 vehicles at 144,000 km do not exceed 130-140 on straight road, 1-2-3 gears have 30% shooting problem, vehicle sees 130-140 in 4th gear and 5 I put it in gear, continue at the same speed. I had poured the catalyst before it was clogged. I did not realize that I had the same problems before after the emptying, I realized that for the last 2-3 months, I did not exceed 130-140 [/ QUOTE] sell it 106 buy quick 190 will go even further with one breath:) [/ QUOTE] my friend, we burn half of what you burn, so you should not sell it, I think the problem will not be sold after this time, I look at the LPG car, I am not satisfied at the time. |
| 08.05.2020 14:56 | # 9 |
I have 110 hp diesel, 6 people in the car, 10 ramps on the highway, I enter with 90, I go with 150, it is based on 200 instantly.
| 08.05.2020 14:56 | # 10 |
dbmaster |
[QUOTE = furkan] I have 110 hp diesel, 6 people in the car, 10 ramps on the highway, I enter 90 with a straight 150 I go straight to 200 instantly I wonder if your problem is from the clutch [/ QUOTE] Just like you said, I have tried so much, there is excellent acceleration, there are no cars, there is absolutely nothing to be done in the car of your friend, but there is nothing to do, so connect it to a computer and control it. can be turbo clears etc. etc. control condition. |
| 08.05.2020 14:56 | # 11 |
this engine is the same as the 110 hp volvo s40 diesel
| 08.05.2020 14:56 | # 12 |
[QUOTE = 26NT023] [QUOTE = ozangenc] peugeot 307 1.6hdi 205 vehicles at 144,000 km do not exceed 130-140 on straight road, 1-2-3 gears have 30% shooting problem, vehicle sees 130-140 in 4th gear and 5 I put it in gear, continue at the same speed. I had poured the catalyst before it was clogged. I did not realize that I had the same problems before after the emptying, I realized that for the last 2-3 months, I did not exceed 130-140 [/ QUOTE] sell it 106 buy quick 190 will go even further with one breath:) [/ QUOTE] :) 106 quik gtı pattern, anl 110, how do you compare the guik with a 307 :)
| 08.05.2020 14:56 | # 13 |
oguzhan29 |
The brother of the turbo could be taking the last day, a golf was taking a 130 tdi car's turbocharged 110u did not exceed, we gave it back.
| 08.05.2020 14:56 | # 14 |
share the result with us
| 08.05.2020 14:56 | # 15 |
I unplugged the air flow meter again the same no change no vehicle does not exceed 140 shows that I am out of order so what does this air flow meter do
| 08.05.2020 14:56 | # 16 |
There is a diesel of 110 in me. I can see 190-200 comfortably on the flat road. There is probably a problem with the catalyst or turbo.
| 08.05.2020 14:56 | # 17 |
dbmaster |
I think the problem from turbo
| 08.05.2020 14:56 | # 18 |
the turbo has a veskeyt stick on it, there is a 10-nut on it, 4 or 5 teeth, lower the stick, shorten the bar, the traction of the vehicle will increase. |
| 08.05.2020 14:56 | # 19 |
dbmaster |
| 08.05.2020 14:56 | # 20 |
oguzhan29 |
brother, you still show what you know, if you found out, would you share it with us?
