Peugeot 307 1.6 xt automatic mind system excess fuel
08.05.2020 17:58 # 1
trking14
Hello to everyone
friends in the last 10 15 days, I have increased in my lpg admission in a way that I do not understand, normally I have caught a 0.33 krş in km. please help why this much consumption increases. Plus, there is no gas consumption in b values, so if I add it, it will burn more.
08.05.2020 17:58 # 2
trking14
I went before for the adjustment and maintenance, if I was not mistaken, I went for the last maintenance 1.5 months ago.
08.05.2020 17:58 # 3
fexzi
There are 10 thousand km of running-in time.
You should make the vehicle overturning and pressure adjustments according to the torque-hp of the model.
08.05.2020 17:58 # 4
trking14
Do you know your values? Bid master, I think I had 41 cents since it is winter right now. 15 20 days ago, my value was 33 km.
In addition, my system is beeping at the AKL gas bit, which means that the gas is over, or if it is still not 5 5 km away with this sound. Otherwise, the vehicle will automatically switch to gasoline with that sound.
08.05.2020 17:58 # 5
fexzi
In my opinion, by saying that AKL has no fixed value, the same model may not keep that efficiency in a different vehicle.
130 thousand fitted lpg right now, 149 thousand, the maintenance periods of your vehicle will affect everything, unconditionally.
You will get "antipollution fault" during the winter months, the exhaust will be noisy, the vehicle will be misfire (install the lpg compatible code spark plug) etc .. be prepared but not big troubles.
