peugeot 307 1.6 hdi comfort right front door electric |
| 08.05.2020 19:49 | # 1 |
| 08.05.2020 19:49 | # 2 |
sonerkyl |
first of all welcome murat. If there is no sound when pressing the right front windshield button, the window electric motor has failed. sensor and mirror adjustment may be impaired. Of course, these may be the problem in the installation line if none of the electrical controls work on the right side of the estimate. it is necessary to disassemble and check the sockets. If electricity is coming to the top priority installation, look at it
| 08.05.2020 19:49 | # 3 |
Cyrus35 |
Did you check the socket in the doorway with the door open? o central lock mirror outside heat glass lifting all cables passing through that socket try to remove and clean and reconnect
| 08.05.2020 19:49 | # 4 |
Thank you for your answers. I think it's about plumbing because they all failed at the same time.
