PEUGEOT 307 1.6 HDI COMFORT 2006 SPEED STABILIZER
08.05.2020 17:29 # 1
dreamcast87
Hello Friends,
& nbsp;
Last Friday, I ordered a cruise control arm for my car from Şahin Peugeot and I was there on Saturday morning at 9. I would like to thank all the hawk peugeot employees for their interest and fast shipping, and I will have some humble questions. On Saturday, we assembled the cruise control arm with my master and adjusted it to the vehicle's base and the engine computer with cruise control and speed limiter. We went to the test a few times, but the arm did not work. Actually, the arm that comes to me has both limit and fixing modes. Although we activated it from the computer, when I put it in limit mode on the mileage screen, it was 30 lmt. We tried hard, but it didn't work anyway, I wouldn't stretch it again and then the stabilizer and speed stabilizer and speed without limit & nbsp; and this time when we went to the test, the arm worked. As far as I researched and understood, the limitation was working only in the 308s. Now the real question I want to ask is that I can't get into cruise control under 70 km. After passing 70, I can put it in cruise control mode and if I want, I can drop it down to 40 km by minus the arm. I wonder if there is a problem with me or I do not understand that there is no code in the original software of the vehicle before it can exceed 70 KM and I wanted to ask you, my dear friends.
08.05.2020 17:29 # 2
hsnsnl
It works at 60-70km, the teacher will be on the speed stabilizer and the 4th gear .. the deactivation modes will be disabled by touching the clutch or brake .. if you want to fix it again, it will be at your fingertips :) but you have to meet the conditions
08.05.2020 17:29 # 3
dreamcast87
Hodja, thank you very much, I was saying that I have a problem with my vehicle :) As I guessed, because in my determination, the vehicle was 4 in gear and 60 to 70. Thank you very much for your comfort :)
08.05.2020 17:29 # 4
qqyyxx
Well, how do you close that part when you put the handle, it was marked where I can attach cc in the previous 206, it was easy to cut, but how to close the plastic when we attach the flat plastic handle in 307. & nbsp;
08.05.2020 17:29 # 5
inceyasar
The 3rd gear starts operating at 50 km / h.
08.05.2020 17:29 # 6
Serkan
The gear and speed conditions are not the same in every vehicle. In my 206hdi, the 3rd Gear is engaged at 40 km speed, Kayıbiraerin 308, 4th Gear is engaged at 60 km speed.
08.05.2020 17:29 # 7
dreamcast87
qqyyxx my friend yes unfortunately it is plain plastic and since i am a meticulous person, everything should be like the original. so after attaching the handle, I cut the neatly by marking the plastic with fine calculations, and then the lower steering wheel cover combined with the upper cover and it's really something super. When it comes to getting started, yes, it does not matter in myself from vehicle to vehicle because it definitely did not start at 50km speed, 4th gear and minimum 70 km speed I observed. After it is activated at 70 km, it can be reduced to 40 km from the arm.
08.05.2020 17:29 # 8
qqyyxx
So when cc is activated on the screen in km counter, warning message appears. So there is a warning that cc is active.
08.05.2020 17:29 # 9
dreamcast87
When you turn the round button on the fixing arm downwards, it switches to cc mode and the text on the km screen appears as
& nbsp; OFF
CC --- and when you press the plus or minus button while driving, then --- it says speed where it says --- you set it according to your own. it's in your brain but it doesn't work room is something different :)
08.05.2020 17:29 # 10
ozknckr
What does the speed limiter do?
08.05.2020 17:29 # 11
Serkan
For example, you limit it to 90 km speed, the vehicle does not exceed 90 km speed, it is disabled for safety only when the bottom makes gas, except that the vehicle does not eat gas when it reaches 90 km speed.
08.05.2020 17:29 # 12
qqyyxx
It does not go up a speed you set or warns you at that speed.
08.05.2020 17:29 # 13
ozknckr
I don't know what speed stabilization means?
08.05.2020 17:29 # 14
dreamcast87
For example, let's give an example, you are going at a speed of 70 km, you have fixed the speed and your feet are out of the gas, the car is going at a speed of 70 km, by the way, let's say you set the limit to 90 km. The vehicle accelerates as you increase by pressing the button, but it accelerates up to 90 km max. If you set the limit to 120, the vehicle will accelerate up to 120 km.
& nbsp;
If you need to give another example, you have fixed it at 70 km speed, then you descend from a slightly downhill place and set it to 90 at the limit. Even if you fix it to the vehicle, it can even pass 90 km depending on the condition of the slope, but if the limit is set to 90, the vehicle does not exceed 90 km again
dreamcast87 2013-04-01 21:30:59
08.05.2020 17:29 # 15
Serkan
Teacher fixing and limiting do not work at the same time, if you turn the wheel up from the arm, limiting works if you turn the fixing down, if you cannot turn both sides at the same time.
08.05.2020 17:29 # 16
dreamcast87
By the way, I tested it fully this evening and came to the conclusion ... As you say, the car is definitely engaged in 4th gear and it is engaged in a minimum of 40 km as a speed :) Because it cannot be engaged in 4th gear at 40 km & nbsp; the car is starting to shake ) It is activated when we go up to 50 km and put it in 4th gear and press the key from the arm ... tested and approved :)
08.05.2020 17:29 # 17
Serkan
At the same time, the limiting vehicle does not slow down when descending, it is related to the accelerator pedal and does not interfere with the brakes.
08.05.2020 17:29 # 18
Alicilik
[QUOTE = Serco05] At the same time, the limiting vehicle does not slow down, it is related to the accelerator pedal and does not interfere with the brakes while descending [/ QUOTE]
How can Serkan keep the balance? The car that gets on its mild slope goes its head
08.05.2020 17:29 # 19
dreamcast87
I was confused in my lines now :) I knew it was wrong when I set the value without limiting it to cc mode. Anyway, my masters are here, friends should not consider my comments :)))
08.05.2020 17:29 # 20
Serkan
It is already going Ali, if the slope is high and the vehicle is over the speed you limit, it does not turn the vehicle, it is stable with experience.
Page : / 2
