peugeot 307 1.6 hdi air filter
08.05.2020 14:11 # 1
ugur
Hi, how to remove the air filter of the peugeot 307 1.6 hdi is a little difficult to remove.
08.05.2020 14:11 # 2
Celalettin
They put the air filter in such a place ... They worked in the service for half an hour to disassemble. They used some special screwdrivers when disassembling. I think you never try. Leave the air filter dismantling to the masters.
08.05.2020 14:11 # 3
The master is a very laborious process, this is inserted into 2-3 pieces to reach the air filter: D I think it should do something :)
08.05.2020 14:11 # 4
ugur
I know I removed everything from the plastic under the glass, I even removed the filter box, but because the location is narrow, I couldn't get it out of the box. If I knew where it was disconnected, I would wear it.
08.05.2020 14:11 # 5
cerci07
Not so hard, my friend
first hdi 16 the cover will be pulled up, then one end of it will be attached to the turbo and one end is the black nose clamps that go to the air filter box.
Do not try to remove the air filter box by breaking it.
If you still can't insert it, I will open the picture with tomorrow
08.05.2020 14:11 # 6
yes first remove the engine cover remove the plastic under the glass filter box is very simple there but be careful breaking
08.05.2020 14:11 # 7
cerci07
http://www.forum-auto.com/les-clubs/section4/sujet275462.htm
Here is the illustrated explanation, not the way I described it, but a different way of holding the ear of the room Sırıtma
cerci07 2010-03-01 23:50:41
08.05.2020 14:11 # 8
ugur
cerci07 my friend thank you, i was wondering about it, when i checked the hand screwed all the screws on the front of the filter box, the back side is not visible, i did not feel the screw when i checked it with my hand, i remove the screw piece by piece. If the vehicle is used in a very dusty dirty area, it may clog even a few thousand filters ..
