Peugeot 307 1.6 hdi (2006)
08.05.2020 19:05 # 1
ckusku
Hello friends, I get water in Diesel error in my Peugeot 307 model car. The tool does not work at all. I researched a great deal, I think the filter needs to be changed. Is there any way I can get rid of this water before I do it? No valve or something to drain the water. Does anyone do this process? What kind of procedure should I follow? Thanks
08.05.2020 19:05 # 2
monalos
If you have bought the diesel oil, water must have entered the filter or outside the filter, change the filter, empty it completely in the tank, add new diesel, if you take care to buy quality oil in the diesel, it will not give this error yet.
08.05.2020 19:05 # 3
ckusku
Thank you very much for sharing your information. How many liters of diesel should I put after filter replacement? I always buy the same diesel, but still have to be careful.
08.05.2020 19:05 # 4
sinka251
At the bottom of the diesel filter, there is a type of water to remove it.
08.05.2020 19:05 # 5
ckusku
Do you have this type in 307 diesel? Excuse my questions, the hood before I did not open for these reasons. When you say air intake with the pump, is it the place where we take the air from the upper part of the hood by hand?
08.05.2020 19:05 # 6
sinka251
You need to check the diesel filter, it will get air from where you say my vehicle must have 1.4hdi
08.05.2020 19:05 # 7
ckusku
I think the filter types and locations of the 1.4 and 1.6 dies are different from each other. I will try the process you said tomorrow first, thank you.
08.05.2020 19:05 # 8
ckusku
Although the friends had problems with the vehicle diesel filter, the problem came out from the battery. The problem has been fixed after the battery change.
