Peugeot 307 1.6 A Strange Problem
08.05.2020 16:58 # 1
Bugra_Han
First of all greetings. I own the 2005 model Peugeot 307 1.6 LPG Automatic Triptonic vehicle. I have a strange problem recently. it also turns the radio off if the radio is on. After 1-2 seconds, the stop and other lights go out and the radio turns on again and only the airbag light remains on. It repeats constantly with intervals. There is no problem doing this.
Those who know the heat of Izmir, who knows the work, knows it. / div>
I thought that the weather had to do with the temperature.
Have you ever encountered a problem like this? br>
I would be happy if it helps. Thanks in advance.
08.05.2020 16:58 # 2
vedat omer
& nbsp; I had the same problem yesterday, it was solved yesterday, look at the battery and the charger.
08.05.2020 16:58 # 3
berk2309
teacher, the problem arises from the big probabilistic conjunctor & nbsp; it happened in me & nbsp; I can't do the measurement correctly. When the charge is too much, the brain protects itself and such problems cost 100 150 lira.
08.05.2020 16:58 # 4
monur
[QUOTE = farewell ömer] & nbsp; I had the same problem solved yesterday, look at the battery and the charger. 1 & nbsp; "Thumbs
08.05.2020 16:58 # 5
Bugra_Han
I will look at the charging dynote. Thanks for your help. If the problem is solved or not resolved, I will write here again.
08.05.2020 16:58 # 6
xxxxxxxxxo
First, take the vehicle to the authorized service. There is a fault record. The problem is that the probability of the following is
1.airbag brain
2.signal arm
3, seat belt.
< div> 4.The sockets under the seat will not be any more than these. The tester will directly tell you which part is the problem.
I say don't spend money in vain
özcan 22nd year peugeot service chief
