Peugeot 307 1.4HDI excessive water loss |
| 08.11.2023 23:20 | # 1 |
| 09.11.2023 01:13 | # 2 |
The heater core might be leaking. Check under the floor mat by the driver's seat to see if it's wet.
| 09.11.2023 17:39 | # 3 |
My car is a 308, 2011, 1.6HDi engine. I experienced the same problem a week ago. The leak had been going on for a while, and my mechanic told me to figure out where the leak was coming from so I wouldn't have to replace any parts unnecessarily. For a while, I'd been opening the hood every evening with the engine running and watching it, and finally, I was able to pinpoint the source of the leak. It was the thermostat. It started out a little, then progressed to leaking all the antifreeze I added. I replaced the thermostat and drove about 500 km, and the problem seems to have stopped. I'm still seeing it, but I haven't noticed any leaks, thank goodness. Have the thermostat checked, sir.
| 09.11.2023 18:57 | # 4 |
[QUOTE=Karahisarli]The heater core might be leaking. Check under the floor mat by the driver's seat to see if it's wet.[/QUOTE] That's the problem. All the water got on the floor mat. Now I'm trying to dry it. Is removing the heater core problematic? Does the dashboard need to be removed? How much will it cost me to replace the radiator?
| 09.11.2023 18:58 | # 5 |
I don't know the price, but my car had to have its glove compartment removed, sir.
