Peugeot 307 1.4 HDI xr has a few faults
08.05.2020 14:05 # 1
delcullu
I bought the car, I couldn't get a ride with peace of mind. It is constantly causing problems. There is no saying to his driving and comfort, but oh, if they don't have these problems. Anyway, I will ask my problems without extending the word.
Problem 1: When I first start the car in the morning, when I load some gas, it throws dark white smoke. It continues for about 10 minutes and is cut off. I don't see this smoke on the long road. I do not feel a problem with the vehicle traction. If I go around 90-100 km per hour on average, it decreases 1 line of oil on the dipstick at 700 km. If I go between 130-150 km, the oil reduction rate increases and I see that there is oil on the left and right of the engine. When I start the car, although there is oil, the digital oil indicator flashes, the indicator shows at 1.
I said, let's go to the highland and go to the ramp with 2 on the ramp. I tried a few times overheat 90 of the 2 lines crossed immediately I pulled over the side of the road, looked at the engine, smoke was coming out of the felt-shaped heat shield on the catalytic converter. officially, we waited for a while, and we continued on the road. Then the heat started to rise when we went downhill while falling downhill. We arrived that way with stop and go. It seemed to me that this smoke started to increase after that day. May I have a gasket burned or how do I know it?
My 2nd problem: When I first bought the car, the horn was playing and now it is playing by its head, not by its head. I couldn't take it to a master. I asked for 600 TL for the service, he said airbag wick or something. "Let's change the car completely," he says, for the horn. How I can fix this problem is more important to me than the problem above. I can't horn. When he stubbornly did not need a horn, he was constantly playing, the sound of the tulip is not what you need. Because of the horn that will break the steering: D: D: D
the delcull 2009-09-09 01:27:09
08.05.2020 14:05 # 2
2, for the problem, buy 50 pieces from the accessory, 50 TL is more beautiful and cheaper :)
08.05.2020 14:05 # 3
delcullu
Sister horn punching was working separately. When I turn the steering, I think something like contactlessness happens. I took it to the industry where the man checked the soundness of the horn and the horn sounded. But when he turns the steering wheel to the left and right, he works according to his head, and not according to his head.
08.05.2020 14:05 # 4
haruncoskun
Hodja, "1. If the engine and the radiator are right, open the cover of the radiator when the engine and the radiator are right, open the door of the radiator, if the engine is bubbling water or squirting upwards, my radiator teacher may also be a part of the oil loss and white smoke problem. If you are on your way to Ankara, we have a master of your job here. We can show your vehicle to have an idea. Regards & nbsp;
08.05.2020 14:05 # 5
delcullu
[Quote = haruncoskun ] My teacher 1. The problem may be a circumference or circumference. If the engine and the radiator are right, open the radiator cover, start the car, if the water is bubbling or gushing upwards, the radiator teacher may be a part of oil reduction and white smoke problem. If you are on your way to Ankara, we have a master of your job here, we can show your vehicle to have an idea Regards [/ Quote]
Thank you harun
I am looking for a masterful person, and there is no proper acquaintance. You know, if you fell into your merciless hand, change it, you can not change it to 5000 TL. I never add the services, I refer them to Allah.
Where can I go to Ankara after your feast, your sister master, Ankara ...
I wonder if the problem would burst out to me if it was circlips? Some say it will make an engine, but there is no sound in the engine, and the traction is nice. I wish it was only circus ...
08.05.2020 14:05 # 6
haruncoskun
[QUOTE = delcullu] [Quote = haruncoskun ] My teacher can open the cover of the radiator when the engine and radiator is right when you know that the problem is a chip or run it. . If you are on your way to Ankara, we have a master of your job here, we can show your vehicle to have an idea Regards [/ Quote]
Thank you harun
our master master's place ivedik OSB 21. cad 574. I do not know about the street price but if you wish we can go together when you come to Ankara, if you want, we will help you with our reference, we will help you with the price.
08.05.2020 14:05 # 7
delcullu
[QUOTE = haruncoskun] [QUOTE = delcullu] [Quote = haruncoskun ] My teacher 1. open the lid of the radiator when the engine and radiator are right, to tell you that the problem may be a hook or circumference. Your smoke problem may also be from circlips. If you are on your way to Ankara, we have a master of your job here, we can show your vehicle to have an idea Regards [/ Quote]
Thank you harun
I went to Ankara, very complicated roads. I am a novice and it has been 2 months since I bought the car: D I am an Ankara Gazi graduate and I thought I know Ankara. But to go by minibus and to go by car was very different. : I was going to go to Ankamall from Xinjiang. I would go from the lower road in front of Ankamall. I wandered, wandered, saw ankara fortress, wandered around, was not the last Ankamall, but we said whether we found an antheres or not, let's see it. It was an adventurous day. I hope I find the momentum: D: D: D
08.05.2020 14:05 # 8
haruncoskun
My teacher, when you come to Ankara, call, give a clear address, we will help you as much as we can.
08.05.2020 14:05 # 9
Murat
Serdar Hodja, if Harun is not available, I will help you as much as I can.
Just contact us before you arrive.
You can find our phone and mail addresses here.
the http://forum.peugeotturkey.com/forum_posts.asp?tıd=5733&title=yelerimizin-meslek-bilgi
08.05.2020 14:05 # 10
emin_usta
meraba,
The performance of the vehicle and the plateau roads are normal. After all, the vehicle was 1.4, and it was my vote .... but now canawarrr: D
The horn is simple. There is a need for an operation under the steering wheel. As the service says, the airbag winding etc. is inserted, but not 600 TL. ..
08.05.2020 14:05 # 11
delcullu
[QUOTE = Murat] Serdar Hodja, if Harun is not available, I will help you as much as I can.
Thank you murat I hope to come ...
08.05.2020 14:05 # 12
delcullu
[QUOTE = the emin_us] hi,
Thank you brother horn is important. When I press it, when I'm not stealing, I'm getting into cubes. When it is not necessary, it works. LOLLOLLOL If I am not afraid of the airbag, I will remove it and I will look at it. it explodes and stays on my hand Tongue
When I say "monster now"? Whatever you did, the vehicle became a monster. Are you sure you can open up a little bit?
08.05.2020 14:05 # 13
tugrabozan
Brother 1. Look at the oil to see if the gasket is burning for the problem. Let's see if there is water in the oil.
08.05.2020 14:05 # 14
ErkanKurnaz
get well soon bro
08.05.2020 14:05 # 15
emin_usta
[QUOTE = delcull a] [QUOTE = the emin_us] hi,
I have 1.4 hdi original, 68 hp, the torque at low speeds sucks. as if the donkey car. 2 years ago I had a chip in Germany to the company I worked with today, now it is around 86 hp (it changes according to the atmospheric pressure) plus the torque at low revs is crucial. Now I am finally withdrawn.I do not get in my car properly. LOL somewhere, somebody called bunch lady has opened a topic, we will come to our shop tomorrow, we will have a new software for her ... that is 1.4 hdi, you can follow the development + formation of the chip tuning from there and the process done there .. so briefly 1.4 hdi "donkey" but chip It is strong like "mule" and it should be 2.0 hdi or at least 1.6 hdi to be like "horse".
08.05.2020 14:05 # 16
hasimayaz
The horn and the airbag are integrated, but it is necessary to look, maybe the problem can be solved. Burning and throwing smoke indicate a serious leap to abuse. Emulsion should be measured and checked
08.05.2020 14:05 # 17
delcullu
[QUOTE = tugrabozan] brother 1. Look at the oil to see if the gasket is burning for the 1st problem.
When the engine is at rest, that is, when I look in the morning, it becomes dark black oil. When I look at the engine after it has been running for a while, it looks like it is transparent. I bought the car, or rather, since this is my first car, I am not very knowledgeable about the engine.
When you say fuzzy, what should be the fuzzy color?
08.05.2020 14:05 # 18
taylan43
Well, brother had bought the same car when my friend first came out, but he could last for 4 months at most, that engine comes very powerless so I hope the engine will get a lot of trouble after a while, hope you won't have any more problems, God help you ...
08.05.2020 14:05 # 19
delcullu
[QUOTE = hasimayaz] The horn and the airbag are integrated, but you have to look at it, maybe the problem can be solved. Burning and throwing smoke indicate a serious leap to abuse. Emulsion must be measured and checked [/ QUOTE]
When the vehicle waits for a few days, it starts to smoke, how to smoke. Like the cloud :) it's so dense white. I use the vehicle every day these days, there is no smoke. I wonder why it happens when you wait.
Someone advised me to use an oil boron additive if there is abrasion, I guess it filled the gaps. Preventing compression leaks reduces fat burning, he said.
1. Is this something useful as they say?
2. What is the additive life? How many months does the effect last?
3. Does it harm the vehicle?
I am wondering if these are useful, I am thinking of buying them.
08.05.2020 14:05 # 20
delcullu
[QUOTE = taylan43] Well, brother had bought the same car when my friend first came out but he could last for 4 months at most, that engine comes very powerless so I hope the engine will get too many problems after a while, hope you won't have any more problems. . [/ QUOTE]
Thanks, Taylan, I hope I don't have any problems anymore. I want to ride with peace of mind yeteeeerrrr LOL
Page : / 2
