Peugeot 307 1.4 hdi AIR FLOW METER cleaning ...
08.05.2020 16:40 # 1
teoman_40
[COLOR = red] Friends are consuming too much fuel than my car should be. They said there could be several reasons for this. One of them is air flow meter pollution. I am waiting for your help on how to clean the air flow meter. I would be very happy if there is an illustrated narration. Also, do you mind cleaning the air flow meter?
08.05.2020 16:40 # 2
toga406
A simple-looking piece under the air filter. I don't think it will get very dirty. However, if your air filter is dirty, the flow meter will increase the fuel consumption by reading that the air entering is low so that it can increase the power. I guess this way.
08.05.2020 16:40 # 3
toga406
you will see if you completely remove the filter part
08.05.2020 16:40 # 4
teoman_40
let the weather improve, let's see how to disassemble :)
08.05.2020 16:40 # 5
teoman_40
& nbsp; Guys, I'm going to clean the air flow meter. Should I use "pad spray" for cleaning or " oil-free contact spray " ? I would appreciate if you write with the reason ... If there is any other information I need to know about this (air flow meter cleaning)?
08.05.2020 16:40 # 6
It is a sensitive and expensive piece.
08.05.2020 16:40 # 7
teoman_40
[QUOTE = laedri] I wouldn't recommend it. It is a sensitive and expensive piece. Make it to a master. [/ QUOTE]
Wouldn't you recommend cleaning or would I clean it :)?
08.05.2020 16:40 # 8
The air meter needs no more cleaning. What problem was there with the vehicle, did you want to try this method?
08.05.2020 16:40 # 9
teoman_40
Should I use lining spray or contact spray?
08.05.2020 16:40 # 10
teoman_40
[QUOTE = laedri] Air pressure meter does not require cleaning. What problem was there with the vehicle, did you want to try this method? [/ QUOTE]
I have a lot of fuel trouble. The friends mentioned that this could also be a "cause." There's a bit of traction.
08.05.2020 16:40 # 11
Replace your air filter first, if possible, get the original parts. If not, clean the butterfly throat to the place where you are maintained.
08.05.2020 16:40 # 12
turbo27
Try it with contact spray, I haven't seen it any more, it is defective and flow meter, but try again, keep in mind.If it does not pull, if the car has a malfunction, if you have more trouble, connect it to the malfunction detection device, it shows almost the malfunction.
08.05.2020 16:40 # 13
taskin
The air flow meter is cleaned with the best electronic circuit cleaning spray, but I also cleaned it with the lining spray and there was no problem.
