Peugeot 307 1.4 HDI (68 HP - 2005)
08.05.2020 21:04 # 1
stfa
Hello to everyone,
When the Peugeot 307 1.4 HDI (68 hp - 2005) is used for the first time and the engine is warm, the idling speed (fabrication data) should be how many rpm.
Even if the vehicle owners are not knowledgeable, I would be glad if they write the data they observe.
Respect and greetings ...
08.05.2020 21:04 # 2
GokhaN
[QUOTE = stfa] Hello everyone,
In general, the idling will be between 800-1000 rpm. The engine does not change in cold heat, and the temperature is usually at 90 degrees. can go between 80-90 depending on weather and road conditions
08.05.2020 21:04 # 3
stfa
First of all thank you for your kind reply.
I'll fix my question a bit and ask again.
The ECU, which we call the brain, is idling for the vehicle in the first message I wrote. It is programmed to keep it constant at how many rpm.
08.05.2020 21:04 # 4
When the engine idling engine is cold, it will be at 1100-1200 rpm, generally it will remain constant at around 800 rpm as the engine warms up.
