PEUGEOT 307 1.4 HDİ 2004 MODEL ENGINE OIL MISSING
08.05.2020 19:10 # 1
R.CaVuS
Hello everyone, about 2 days ago, I bought a 1.4 hdi xr vehicle with a 2004 model 150,000 kilometers of one piece (left fender, no change) painted. When I took the car to the Peugeot special service, he connected the computer to the car's brain, looked at his engine and said the following.
1- There is very little oil leakage in the engine of the vehicle. (Someone from whom I bought the vehicle trusted and knew that the engine did not reduce oil)
2-He said that when the vehicle lifted the oil dipstick and looked at it, it blows very little steam.
3-He said that the printing pad is at a sufficient level.
4- He said that the engine was alive and not worn.
He said there was no blowing in the 5-Turbo but there was also a slight oil leak in the turbo and the oil leaks were not significant.
Guys, is this a problem that will be enlarged? The result is that I bought the car for 16,000 TL, I don't mind much, but I don't want it to leave me on the road. He also asked for 600 TL for the repair of oil leaks. Thank you in advance for your answers. Stay safe.
08.05.2020 19:10 # 2
talip206
You bought the 2004 model 307 for 16 thousand tlies. It is painted in one piece and unchanged. Even 206 is difficult for that money. Well, I was very surprised. I hope you will be satisfied using it.
08.05.2020 19:10 # 3
vpro
Sir, good luck, you bought it at a good price.
08.05.2020 19:10 # 4
madblueblacksea
When I heard the price you got, I forgot your problems and focused on the price Shocked
Where and how much oil leaks are important. I do not think it will be a problem if it is not from the crank or eccentric seal (high probability of lubricating the back) and does not require you to add additional oil until the oil change, except for visual and psychology.
08.05.2020 19:10 # 5
Ozel6521
Good luck use it. Well, the price is very good at this time. Three years ago, I bought 150.000 at 206.500 and I bought it a little more than this price. For this price, I think that the trouble for the car is nothing. Smile
08.05.2020 19:10 # 6
R.CaVuS
Guys, thank you very much. I don't know the market value of the car too much. However, I did not get a good answer about my problems :) I am still waiting for your answers :) Regards ...
08.05.2020 19:10 # 7
R.CaVuS
No one can answer ..
08.05.2020 19:10 # 8
talip206
I think there seems to be no problem. If you use a little and give information about how much oil is missing, we can comment accordingly. If you want the turbo to last longer, do not stop the vehicle immediately. Let it idle a little, stop like that
08.05.2020 19:10 # 9
R.CaVuS
Thanks
08.05.2020 19:10 # 10
R.CaVuS
And why is the turbo coming into play at 2200 rpm?
08.05.2020 19:10 # 11
Ozel6521
I think there is no problem in your vehicle. I don't think you will leave it on the road, at least because of what you say. I hope you will be satisfied using it. Accident-free riding. Smile
08.05.2020 19:10 # 12
berk2309
If it comes into play at 2200, I think there is a problem.
08.05.2020 19:10 # 13
KILIC
Good luck and trouble-free driving, the price is very good, but at this time 307 is very good. For those cars in that model, I don't have those lubricants normal 600 TL. turbo 2200 I think it is normal, the car is already running in the 900-1000s when it lifts the car reaches 1500s when I lift the car, it would be a bit early for me to get into the peat.
08.05.2020 19:10 # 14
R.CaVuS
I hope you will not leave thanks :)
08.05.2020 19:10 # 15
R.CaVuS
[QUOTE = berk2309] I think there is a problem if it comes into play at 2200, I think it should be very high at 1500 and our 307 and linea fiorino are at 1500 [/ QUOTE]
What should I do to enter 1500?
08.05.2020 19:10 # 16
R.CaVuS
[QUOTE = KILIÇ] Good luck, trouble-free driving is very good, the price is 307 so good at this time. For those cars in that model, I don't have those lubricants normal 600 TL. I think the turbo 2200 is normal, the vehicle is already running in the 900-1000 roles, it reaches 1500s when lifting the car. ]
I think it should open 1750 normally
08.05.2020 19:10 # 17
Designbyonurkaya
Well, my teacher, I have your oil in my car, as you said, and there is zero engine, and there is steam in the same way and my master, who I trust very much, said the same things so they are generally in all dies and said it is not a problem to be bought.
08.05.2020 19:10 # 18
Designbyonurkaya
Well, I'm in turbo at 2200, but love the one who can keep the car on the road :)
08.05.2020 19:10 # 19
R.CaVuS
[QUOTE = hulkonur] well, my turbo enters at 2200, but love the one who can keep the car on the road:) [/ QUOTE]
When I switch to Turbo, my vehicle is also very good but it is very bulky before passing.
08.05.2020 19:10 # 20
xmen
first of all, your car is auspicious ... you bought it at a really great price ... when it comes to your problem, my previous car was ford fiesta 1,4 tdci. Since peugeot and ford use the same engines, let me answer accordingly .. my fiesta also had such lubrications. When I showed it to the master, he said that these are normal, even these are evaporation, and will not cause any problems. so in summary, this is normal for 1.4 diesels. There was absolutely no oil reduction ... when it comes to turbo, it should be between 1500-2000.
Page : / 2
