PEUGEOT 307 1.4 COMFORT RADIATOR PROBLEM.
08.05.2020 21:26 # 1
BENMAHSUNBEY
Hello.
First of all, I would like to state that I am a new member of the form. I have now become part of the Peugeot family. I want to express my question. I bought my vehicle in September 2019. After buying it, 4 tires changed, the battery changed to 75, I did the necessary oil maintenance. Because of the winter months, I put Antifreeze on my vehicle in December. When the master drained the old antifreeze in the engine, I saw it flow in such mud color. After a while after I put the new antifreeze in blue color, I saw that the car was missing antifreeze from the part they called the thermostat bed on the right side of the engine, and I made this piece with labor, paying 270 TL. Now that I am happy, I see that the car has missed antifreeze from the top of the Radiator, that is, the iron part of the radiator and the plastic part above it. It's not too extreme, but annoying. When I asked the master, he said you will have to change it, but is there any idea what should I do? Thumbs Down Thank you from now. Best regards. Clap
BENMAHSUNBEY 2020-01-26 01:36:09
08.05.2020 21:26 # 2
ismailkaya
Replace all, even change the pipes, change the thermostat, and discharge the radiator water directly from the master.If he changed the taste water, he made the air, then I thought he blew the water from the reserve water tank, and if it was removed from the reserve water tank, it was good to remove the pipe from the reserve water tank, but if you have a drain, then it is good. als days
08.05.2020 21:26 # 3
Exactly, you should change radiators and hoses. so I had a seal on my old car.
08.05.2020 21:26 # 4
ismailkaya
The engine version of your vehicle's engine type 1.4 16v 90 hp?
08.05.2020 21:26 # 5
BENMAHSUNBEY
Yes, it is true.
