Peugeot 306 Wiper Problem
08.05.2020 21:10 # 1
Bayram96
Hello to everyone. I am having a wiper problem in 2000 model 306. When I start spraying water, it wipes up to the last stage, it stands in the wrong place above, in the middle, etc. When I press the single wipe, there is little trouble, it keeps no problem. I have replaced the wiper timing roles with the original, but can the problem still help if anyone is in the same press?
08.05.2020 21:10 # 2
platinium306
Hello, first of all, the problem is not big, only the wiper motor needs to be disassembled, cleaned and lubricated a bit.
08.05.2020 21:10 # 3
GokhaN
If you don't get your friend checked first, stop by a cerebellum
08.05.2020 21:10 # 4
Bayram96
Thank you, there was a blockage in the part of the wiper motor, the water accumulated and the flow was inside.
08.05.2020 21:10 # 5
platinium306
The 306's have the following drain hole under the wiper motor, leaf etc. over time. it closes the hole and because the rain water does not flow out of the hole during the washing, the wiper motor starts to oxidize in the water. I had the same complaints, and I solved it myself by cleaning and maintaining it, thankfully. you won't get clogged. platinium306 2019-03-02 20:21:08
08.05.2020 21:10 # 6
Bayram96
Thank you, as you say, I know the 306, the soil, the water, the water, the water, the water, the water is wet, I know the new 306. Thanks to the small problems, thank you.
