Peugeot 306, The Problem of Failure to Drive
08.05.2020 14:57 # 1
ctosun
Regards, greetings to all forum members. Although I know the site for a long time, I just joined you. I have a problem that I couldn't investigate much and I wanted to share it with you. I am waiting for your feedback.
I have 99 Model Peugeot 306 Sedan, the vehicle is equipped with sequential LPG. The first start works smoothly with gasoline, it eats well where it stops, there is no cutting, but as soon as I move, the gas cuts, sometimes it stops, sometimes it gives gas again and continues, but it keeps cutting. It does not cut when going downhill, it does not cut when going back and forth, It cuts when straight road and uphill straight up. As traffic in Istanbul is known, if the LPG is near to the end when it remains in a lot of traffic, I am unable to progress in the traffic while on gas. There is no problem in LPG. Thanks in advance ...
08.05.2020 14:57 # 2
Onur
can be from the pump
08.05.2020 14:57 # 3
tugrahan
vehicle 1.8 16 valve?
If there is a cecoli from the same vehicle, a very knowledgeable friend ask him, he knows
08.05.2020 14:57 # 4
thank you tugrahan :) there is much more to learn from me
If we are concerned about the problem of the vehicle, it seems to me that the honor is like a pump. Because this variable is variable according to the pain conditions when it is variable. do you keep the gas in the tank less? For example, fill in half a tank or more.
the cecol 2010-11-23 14:04:56
08.05.2020 14:57 # 5
Onur
As the pump or float cem teacher said, keep the tank above a certain level, most likely the fuel level is not enough, the fuel does not come according to the angle it stops.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
