|   | peugeot 306 sedan Fault |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 306 | |
| 28.02.2022 16:45 | # 1 |
|  secuestrados | |
| 01.03.2022 11:59 | # 2 |
|  sonerkyl | |
no bro, misfire at lower revs usually makes it from spark plugs and coils. If there is LPG, the distress will be felt more. Does it do this only on gasoline or LPG demi?
| 20.03.2022 23:13 | # 3 |
|  secuestrados | |
It's the same in petrol, it does the same in lpg, the vehicle works unevenly at idle.
| 22.03.2022 18:04 | # 4 |
|  sonerkyl | |
then first check the coil and spark plug. Also have the throttle and idle sensors checked. If it is excessively dirty, it will break the idle.
| 06.05.2022 22:32 | # 5 |
|  secuestrados | |
Sir, I am in Ankara. In ostim ivedik infallible, do we only have a peugeot-looking master?
| 09.05.2022 09:03 | # 6 |
|  sonerkyl | |
There are mas peugeot abdurrahman and sefa masters in ivedik. they will help you go
