Peugeot 306 Heater problem
08.05.2020 16:14 # 1
zavur
Friends & nbsp; The owner of my car before me got the heater connected to the air conditioner button, the heater was turned on without turning on the air conditioner. I went to the auto electrician for this problem, the electrician said it was too long, maybe he would remove the torpedo or something, is there really a need for a simple key separation? Or is the electrician doing my feet to me?
The worst thing is that the air conditioner is stuck in the air. Reviews
08.05.2020 16:14 # 2
First of all, I am of the opinion that it is necessary to translate the system of the vehicle to its original. Because why open air conditioning for hot air? Since the temperature is already obtained from the liquid in the engine's cooling system, what does it mean to run the air conditioner and consume additional fuel ???
08.05.2020 16:14 # 3
zavur
I went to the satin electrician because I thought so, but I think the man is unnecessary to separate a key & nbsp; I am also a student of a person who normally uses the air conditioner very rarely. Reviews
08.05.2020 16:14 # 4
zavur
I solved the heating problem, but I did it by converting it to the original system. According to reaching a piece, the chest will be removed and salted in the piece. I bought the cable that my previous cucumber had connected to the air conditioner without thinking, and I had it connected to the button that demisted the rear window, called the resistance, and it was better than the original. Because I & nbsp; I always forgot to use the resistance to defog the rear window in the morning & nbsp; "Laughter"
08.05.2020 16:14 # 5
There's been quite a solution. It seems that you forgot to open the resistivity of the rear window, you do not look at the inside mirror. If it is redundant, you can insert it "Laughter"
08.05.2020 16:14 # 6
zavur
Looking at looking subconsciously "I saw it is enough for me, I will go to sati 4 & nbsp; no need to waste miles" & nbsp; when it happened, I did not press it at all, it started printing after a while & nbsp; "Laughter" "Laughter" "Grin"
08.05.2020 16:14 # 7
zavur
I went to Samsuna on the winter day, I still haven't pressed this button. /smiley36.gif "border =" 0 "alt =" Laughter "title =" Laughter "/>
08.05.2020 16:14 # 8
[QUOTE = poor] I went to Samsun on winter day, I still haven't pressed this button. img src = "smileys / smiley36.gif" border = "0" alt = "Laughter" title = "Laughter" /> [/ QUOTE]
& nbsp;
There is generally no steam problem in 306s. Thanks to the air circulation inside the vehicle, the steam in the rear window disappears by itself. It would be very rare for me to open the rear window resistance.
& nbsp;
But the steam event can cause a very big problem on some vehicles. Whatever you do, steam may not flow ...
08.05.2020 16:14 # 9
redline
306 did not bother me in this regard, there is no problem in my own car because of the rear window fog, but yesterday I went to Balıkesir with a company car, neither side windows nor the rear window's vapor did not know somehow alt
08.05.2020 16:14 # 10
malazgirt18
[QUOTE = poor] I solved the heating problem, but I did it by converting it to the original system. I did the TURK style. circuit eletrironik ti electrician said that in reaching a piece, the chest would be removed and salted in the piece. I bought the cable that my previous cucumber had connected to the air conditioner without thinking, and I had it connected to the button that demisted the rear window, called the resistance, and it was better than the original. Because I & nbsp; I always forgot to use the resistance to defog the rear window in the morning & nbsp; "Laughter" [/ QUOTE]
Me There was a problem near you too, my brother was working in one setting and constantly when I turned the fan contact
I provided a center console `` Air control panel '' from a crashed vehicle. I changed it myself.
