Peugeot 306 GTI Help ??
08.05.2020 16:56 # 1
DeNvEr64
Dear Peugeot Lovers, & nbsp; "Smile"
I bought Peugeot 306 GTI - 6 about 1 month ago. God willing to ride with goodness. Hopefully.
1. I faced team problems. For example, the cooling system, that is, the radiator fans are connected flat and connected to a choke. I showed it to an electrician and if I think there is a problem in his brain, they said, let's renew its installation. Do you have an idea? Also, the door automatic does not work. As I get on Tofaş, I open it with my own hand at the other door.
2. normal but when it closes, the top of the left hangs up and scratches the glass.
3. When I load a little (there is a silencer exhaust), the smell of gasoline is coming.
So I couldn't make sense of the problems related to the brain. >
Could those who have information briefly inform? What kind of path should I follow? We have elders and experienced friends who pass more or less through these roads. Otherwise, we will go to the industry and spend money without knowing a lot of spheres. I am a stranger to my hometown, so they do not charge a lot. "Ouch"
DeNvEr64 2012-08- 13 16:23:45
08.05.2020 16:56 # 2
DeNvEr64
up .. "Stern
08.05.2020 16:56 # 3
scorpions_64
[QUOTE = DeNvEr64] Dear Peugeot Lovers, About 1 month ago I bought Peugeot 306 GTI - 6. God willing to ride with the goodness, God willing. 1. I did not have the opportunity to look a lot while buying my vehicle and I encountered some problems. For example, the cooling system, that is, the radiator fans are connected flat and connected to a choke. I showed it to an electrician and if I think there is a problem in his brain, they said, let's renew its installation. Do you have an idea? Also, the door automatic does not work. As I get on Tofaş, I open it with my own hand at the other door. The sunroof is quite normal when opening, but when it closes, the top of the left hangs up and scratches the glass. When I put a little load on the car's gas pedal (there is a silencer exhaust), the smell of gasoline is coming. What kind of path should I follow? We have elders and experienced friends who pass more or less through these roads. Otherwise, we will go to the industry and spend money without knowing a lot of spheres. I am a stranger to my hometown, so they do not charge a lot. [/ QUOTE] obooowww nettin you so, scrapper sell it with your weight account .1- fans will be connected to the old system, that is to say, it will most likely be looked at the temperature sender or the brain. Continue the door locks as well, it looks nice 80 model taurus looks like your vehicle: D2- late: D3- I think the problem with your gas pedal is about the ignition, of course, the misfire related problem. There is a shortage, no kicking, etc. problems like? or if they canceled the floor, which they canceled 90%, it is likely that the petrol will blow out raw.
08.05.2020 16:56 # 4
DeNvEr64
Yes, thank God there is no misfire in my vehicle, did I press it in terms of speed, war, frankly pleased .. Well, now 2.0 vehicle:)) & nbsp;
Well I passed the doors and sunroof But if there is a problem war in this brain, it makes me very troubled. It scares me. How do we understand or solve this fold cancellation event? & nbsp;
08.05.2020 16:56 # 5
scorpions_64
[QUOTE = DeNvEr64] Yes, thank God in my car, there is no misfire, I have pressed in terms of speed, frankly. and I passed the sunroof, but this is a problem in the brain, is there any problem? It frightens me. It scares me. How do we understand or solve this cancellation event? & nbsp;
& nbsp; or take it under the vehicle. catalyst cancellation is what we call fold cancellation. it makes the most sense to connect to a pp 2000 device. la tolga come together alam bi pp2000 somehow it is always needed ...
08.05.2020 16:56 # 6
DeNvEr64
I guess someone who bought pp2000 didn't know how to use it, as he called me a direct brain. & nbsp; "Party"
