Peugeot 306 engine temperature
08.05.2020 16:13 # 1
zavur
My friends car is working at 90 degrees, is it normal? & Nbsp; The fan turns on after stopping the engine? & Nbsp;
08.05.2020 16:13 # 2
It is normal up to 100C. But I think the fan must stop when the ignition is off while the fan is running. This is my vehicle & nbsp;
& nbsp;
Either there may be a difference in the original of the vehicle due to the model year, etc., or the electrical installation may have been tampered with it in the shorter time. I do not find. If you say why;
& nbsp;
After the engine stops, it stops in the circulation. There is no benefit to anyone cooling the water in a non-spirited radiator. In addition, it also means that it has a battery ...
CeCoLi 2011-10-10 15:18:33
08.05.2020 16:13 # 3
zavur
I was relieved, thanks "Laugh" the fan was working in my old car like this, after I stopped the car I stopped asking to cool the car after it stopped had said to. Personally it seemed ridiculous to me
08.05.2020 16:13 # 4
[QUOTE = poor] I was relieved, thank you "Laugh" my fan was working this way, a master I asked asked to stop Then he said to cool the vehicle after the circulation stopped. Personally it seemed ridiculous to me
& nbsp;
Short story: Our master shook the bomb that pulled his pin "
& nbsp;
Unfortunately there are a lot of people on the market talking without knowing ... When the circulation stops, the engine won't cool
After the engine stops The operation of the fan is not beneficial to anything & nbsp; but it does the opposite and nbsp; the damage I have explained above
& nbsp;
When the ignition is switched off, it will be the most correct behavior to wait for & nbsp; to stop if the fan is running before the engine stops. I think ... cecol the 2011-10-10 15:26:42
08.05.2020 16:13 # 5
OkaN
I have never heard your voice :) As the brother said, does the contact on ours stop?
08.05.2020 16:13 # 6
zavur
Working iron does not rust & nbsp; "Laugh" Could the thermostat be broken?
08.05.2020 16:13 # 7
OkaN
After stopping, electricity cut & nbsp; but: D
08.05.2020 16:13 # 8
zavur
Let me be your best & nbsp; "Laugh"
08.05.2020 16:13 # 9
OkaN
Take & nbsp; Look at it, as 1 brother said to him, someone has tampered with him before
08.05.2020 16:13 # 10
[QUOTE = poor] Running iron does not rust & nbsp; "Laughing" Could the thermostat be broken? [/ QUOTE]
& nbsp;
Thermostat has nothing to do with the fan ... The thermostat has 2 faults. It will either stay hungry or remain closed. The only problem is that the engine heats up at night and it does not reach the operating temperature according to the burns, so it dusts in the heating efficiency. and the engine overheats ... In the meantime, no matter if the fan is running or not ...
08.05.2020 16:13 # 11
zavur
Brother you know these things well "grin" no expansion vessel in our vehicles, you put the water from the radiator. What is the weather like? zavur 2011-10-10 15:53:41
08.05.2020 16:13 # 12
[QUOTE = poor] Brother, you know these things well. do not make air while putting it, if it does, what is the weather? [/ QUOTE]
& nbsp;
The expansion vessel is where you put the water above the radiator "
& nbsp;
Does not air when putting water. If he had air, he had already done it. If you did, you would get it from the air vents. You can check if there is air from the air vents, from the air radar etc ... This is the heat of the experiment ...
08.05.2020 16:13 # 13
zavur
Hmm, I understood thanks & nbsp;
08.05.2020 16:13 # 14
The fan stops when I close the 1998 306 griffe contact in my vehicle.
08.05.2020 16:13 # 15
[QUOTE = OKANKYM] Fan stops when I turn off the 1998 306 griffe contact in my vehicle. [/ QUOTE]
& nbsp;
Here it is actually already "Blink"
08.05.2020 16:13 # 16
I wondered why now, after working for a maximum of ten seconds. It does not work after a long road, but if I do stop and stop, it works in traffic.
08.05.2020 16:13 # 17
OkaN
I guess mine is even broken I have never heard the sound: D & nbsp; "Grin" how do you feel it & nbsp;
08.05.2020 16:13 # 18
I Love My Pug
When 90 exceeds, listen without stopping when it passes "Grin" "Grin"
08.05.2020 16:13 # 19
lau5
I came across once, I left the car to the parking lot, after the stop, after the fan operation, there was no doubt in my mind, I returned, I started it again, I stopped again, it was still working. Mine played acep? :D
08.05.2020 16:13 # 20
In 306s, the technician writes the booklet at 97C ... I see 100 on the display and the fan hurts. But it is not after after 90. When the indicator is officially 100 ...
Meanwhile, all the roles and & nbsp; musurs are new ...
& nbsp;
He was working the same way, without changing the role and the staff. If you say why you changed it, once the fan caused by the role did not open, I started the fans with a lively behavior. One of the musurs was ill. it was moving the indicator. In order not to experience the same situation again, I have renewed all the roles and staff ... Now I am comfortable. Seriously, everything is cramming. Don't let the evil look ...
CeCoLi 2011-10-18 14:04:26
Page : / 3
